Let the fun begin or what the hell have I done
#41
Well, not much new to post other than more new parts.....Replaced all the rear end seals as on was leaking....I guess the Diff was low and leaked when it was full....Get service from the PO. Replaced bought auto trans lines as one had a leak.
Dropped the tank, cleaned up and painted that and the area above it. New tank straps, felt, painted the tank.
Just buttoning up the little stuff and it should be ready for a test drive in a few weeks.
Karsten
Karsten
Almost there! Good luck on the flog and be patient towards the end! It's hard not to rush, when you're right, frigging there!
Post pics when it's on the driveway!
#42
The only thing I haven't found is a new wiper control/AC vent that goes above the gauge panel.
Karsten
#43
Cool! If you re going the entire interior route, may I suggest that you do the dash wiring first? If the seats are out, you'll have an easier time getting it in. Just finishing mine as we speak!
#44
Now, another delay....this damn thing is gonna fight me to the end but I will win.
Dropped the tank to clean up above it, replace the screen, clean out the tank, replace the felt and straps......Now pin holes in the tank.
There goes another 2 weeks waiting for the tank to be boiled, welded up and the inside coated and $200.00. Then I need a sending unit O ring seal.
I could just buy a new tank but it wouldn't have the AO what ever logo and then it would still need to be coated.
There can't be much more that can go wrong as now everything is new under the car.
Karsten
#46
Tank
I have a complete new dash wire harness and I wont mess with it. The guy doing the interior will be tasked with that and he does a lot of custom stuff.
Karsten
Karsten
Bill
#47
Karsten
#48
We thought we were done with this stage only to find a leaking brake caliper and power steering ram. I don't think there is anything more that can be replaced at this point under the car.
I have driven it twice now but that was before it was dialed in and it had a little lag. So far the 1st stage has taken 11 months or so it seems.
Karsten
Karsten
#49
Karsten
Karsten
#51
Nam Labrat
Received 4,179 Likes
You're doing a f-i-n-e job!
(mine is back in the garage with a puddle of coolant under the engine after two "shake-down" cruises in two days....."Gremlins 2 / Me 0............ )
#53
Everything is back together, tuned, sounds like a raped ape, nice lope to the cam and it sound bad. But from 0-10 miles an hour it falls flat on it's face with a stock spec Torque Converter. After 10 MPH it will get up and flat scoot....
So now I need a 2300-2700 RPM High Stall Converter which means pull it all down again......Hate to do it but I want it right to start with as I don't want to just get a little chirp if I get on it....I want some smoke!
Karsten
#54
Doorgunner, Thanks.....I am beginning to think my Gremlins are gonna win.
Karsten
Karsten
#55
Stall Converter in, transmission and exhaust reinstalled. The Vette is said to run great now.
Now a little issue with it starting all the time. I opted the upgrade to PerTronix Ignitor Solid State Ignition and it seems temperamental.
After calling Summit I was told to get rid of any Resistance wires or Capacitor Blocks attached to the distributor.....Done and still issues.
Called again and this time I was asked about the mechanical tach and if I was running the original distributor from 1973.....I have no idea but most likely it was the original 40 plus year old distributor and likely worn beyond spec for the Pertronix unit to function properly.
Well just unpacked a new HEI distributor with 50,000 volt coil so hopefully this fixes the problem.....I want my car back after close to a year so I can get started on the interior.
Karsten
Karsten
#57
Replaced the original 1973 distributor with HEI unit, replaced plugs after 15 miles on old distributor and no spark. Put 60 miles on the motor today but it wasn't getting up to temps seeing as it is a toasty 20 degrees today.
Needs some tweaking of the carb as it is still way rich. Seems like it is loading up fuel wise but it is running. Ran right up to 85 MPH without a problem. 75 is nothing but at lower speeds it is getting way to much gas.
One step closer to the interior shop.
Karsten
Karsten
