Going through the vette today and found this.
The dealer pre-delivery inspection form. Its in great shape. Has the engine and trans numbers which I can not decode.
Inspected on 8-3-81.
Now if I can only find the window sticker.
Received 1,468 Likes
Cruise-In II Veteran
St. Louis or Bowling Green car? The 8/3/81 date on the new car prep sheet could indicate either. If Bowling Green, contact the NCM and see if you can obtain a copy of the build schedule for your car. https://store.corvettemuseum.com/ser...buildsheet.asp
If it's a St. Louis car, contact the Allied-Vaughn folks http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice.
If it is a St. Louis car, it's one of the last ones. St. Louis finished their last car and closed on 8/1/81.
