Fron fender door alignment
Old 10-03-2013, 06:55 PM
rgpta
Support Corvetteforum!
rgpta's Avatar
Default Fron fender door alignment
can someone provide instructions how to adjust the fornt fenders on 1976 corvette. After body mounts installed, everything seems mis aligned.
The hood is raised and little gap at bottom of drivers side door.
Pictures below.
[ATTACH]Name:  IMG_0271.jpg
Size:  32.3 KB[/ATTACH]
Old 10-03-2013, 08:03 PM
billcarson
billcarson's Avatar
you may have a weak frame.
Old 10-03-2013, 08:40 PM
Jig A Low
Jig A Low's Avatar
did you replace the body mount that holds the nose to the frame, the kit I bought didn't come with new mounts for the nose so I had to buy one seperately.
Old 10-04-2013, 07:23 AM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
How were your gaps before you replaced the mounts? Did you use the factory shim stacks from the old mounts on the new?
Old 10-04-2013, 08:57 AM
540 vette
540 vette's Avatar
It looks like the nose is drooped. If you adjust the door to correct that gap you may mess up the one between the door and the quarter.
Old 10-04-2013, 09:05 AM
Roco71
Roco71's Avatar
What does the rear of the door look like?
Old 10-04-2013, 09:47 AM
arkus
arkus's Avatar
just a thought :::::::
you might have to realign all of the front panels .
once you start with one , it could upset all of the other ones .
Old 10-04-2013, 01:08 PM
Korevette
Korevette's Avatar
I would work from the 1/4 forward meaning align the back of the door to the rear 1/4 and then work forward to the fender/door gap.
You may need to fit the best you can overall. They were not perfect and if you compared many they will all have some variance. I nearly lost my mind over this but I got it to the point I am satisfied.
Old 10-04-2013, 03:30 PM
Roco71
Roco71's Avatar
When the door is open can you move it up and down by lifting on the end. I am thinking perhaps the hing bushing is worn.
Old 10-05-2013, 10:42 PM
lvmyvt76
lvmyvt76's Avatar
mine was like that when I took it in for a new paint job, the painter re-aligned the front mounting on the radiator shroud to bring the front upward and close the gap, now, the older cars never did really have much quality control on gap-age, at the factory, so don't expect miracles like the newer ones. You can fill in the wider gaps with fiberglass if you want them perfect, I did not.
Old 10-06-2013, 04:35 AM
doorgunner
Nam Labrat
doorgunner's Avatar
Received 4,173 Likes on 2,735 Posts
I have a similar problem......it is a must to replace worn door hinge pins and bushings. And check the frame for damage/rusty-weak spots.
Then do what the guys said about adjusting the gap between the rear of the door and the body....and then adjust the fender(front and rear of it)...then the hood if necessary.
I am learning as I go with a lot of help from the members.
Old 10-06-2013, 02:15 PM
rgpta
rgpta's Avatar
Thanks for the replies. I actually replaced all door hinge bushings. prior to having mounts done, this wasnt an issue.
Old 10-06-2013, 02:16 PM
rgpta
rgpta's Avatar
Only replaced the 4 body mounts, didnt know there are mounts for the nose.
Old 10-06-2013, 02:17 PM
rgpta
rgpta's Avatar
I had the Corvette Center In Newington CT replace the mounts. so I hope they used the requried shims.
Old 10-06-2013, 02:18 PM
rgpta
rgpta's Avatar
Rear door is fine, same gap and height as reare quarter.
Old 10-06-2013, 03:37 PM
havesometo
havesometo's Avatar
[QUOTE=rgpta;1585105452]Only replaced the 4 body mounts, didnt know there are mounts for the nose.[/QUOTE
When you say you replaced 4 body mounts. Is that 2 on one side and 2 on the other or 4 on one side and 4 on the other?
Old 10-06-2013, 06:39 PM
rgpta
rgpta's Avatar
all 8 body mounts
Old 10-06-2013, 07:06 PM
havesometo
havesometo's Avatar
There's only 8 body mounts. Sorry I'm not going to be able to help you. I'm in the exact same boat you are with my driver side. But I'll keep following this to see if someone can help you and me.
To Fron fender door alignment
Quick Reply: Fron fender door alignment
