Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-28-2013, 06:43 PM   #1
929nitro
CF Senior Member
929nitro's Avatar
Default New Trailing Arm Help
I am putting in new offset trailing arms in my 75. Do I need to have the studs that hold the bearing housing pressed into the arms or can they be drawn in with spacers and a nut like wheel studs are? Thanks in advance for any help.
929nitro is offline   Reply With Quote
Old 08-28-2013, 11:48 PM   #3
929nitro
CF Senior Member
929nitro's Avatar
Thanks for the videos, they are very informative. Unfortunately they don't deal with my issue. On the new trailing arm the four studs are not installed and I need to know if it is safe to pull them thru with a nut like you would a wheel stud or if they have to be pressed in in a press.
Old 08-29-2013, 12:17 AM   #4
MakoJoe
CF Senior Member
Most of the time you can tap them in with a plastic mallet to take hold then use a socket to pull them in the rest of the way. OK I understand what your asking. I used to have to replace studs all the time on an axle when I did tires for a living and did them on the car. Best way is pull it and use a press but it can be done on the car with a plastic mallet and get it in far enough so you can use a wrench to pull it the rest of the way in. It needs to get a bite first or you will just spin in it before it takes hold. 1/8 to 1/4 inch is when you can turn the wrench otherwise it will strip and not take hold. Try and line up the new splines before hand after you pounded out the old studs. Feel for it you will feel it click into place than pound the new studs in place. After they stick in the same pattern as the old ones use a socket to pull them the rest of the way in.
MakoJoe is offline   Reply With Quote
Old 08-29-2013, 12:32 PM   #5
929nitro
CF Senior Member
929nitro's Avatar
Old 08-29-2013, 03:28 PM   #6
Kevin68
CF Senior Member
Kevin68's Avatar
I wouldn't use the nut to pull them in. When you are not all the way in and you are torquing them you run the risk of stripping the splines. Set the control arm up in a vice and tap them in with a ball peen hammer and get the heads properly seated on the control arm. You will be able to tell easily if it is all the way seated by the sound of the hammer. If remember correctly, it only took 4 or 5 firm hits after you get it started to make sure its going in straight.
I'll add that you want to make sure the splines are lined up before you start with the hammer
Kevin68 is offline   Reply With Quote
Old 08-29-2013, 09:19 PM   #7
MakoJoe
CF Senior Member
Yea you can pull them in with a wrench or socket after they are seated into the spines. You will need to torque them down with a torque wrench at about 85 FT of torque. The hammer does not finish the job Once I got them seated I used to use an air Impact Tool at a very low setting to seat them. Than use a Torque Wrench on the Steel Wheels at 85 FT of torque. Hope it all works out well
Reload this Page New Trailing Arm Help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Broken Wheel studs 68Thunder427 C3 Tech/Performance 5 05-20-2014 02:34 AM
Clunk/rattle sounds coming from rear trailing arm? SonOfGaladriel C3 Tech/Performance 4 03-19-2014 03:38 PM
Offset trailing arms, 31 spline spindle lurch59 C3 Parts for Sale/Wanted 11 03-08-2014 09:27 AM
Trailing arm spindle support stud torque specs GPGG70 C3 Tech/Performance 7 12-13-2013 11:34 PM
need some leaf spring help Jazper24 C3 Tech/Performance 2 12-11-2013 06:50 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
