Bypass Heater Core
Bypass Heater Core
I am wanting to bypass the heater core in my 78. would it be ok to connect the 2 hoses that go to the water shut off valve ? and what size connector would I need ?? Thanks for your help..
IMO if you connect them hot water will still circulate through the core.
Put a brass or stainless steel 1/4 turn ball valve inline.
Your hoses may have been changed at some point. Mine is 5/8"id if i recall.
If its an A/C car, for some reason I think the hoses are different sizes. Somebody with vastly more knowledge will chime in I'm sure.
Serach "heater shut off" here. LOTS of threads already.
dodosmike
dodosmike
Thanks for the reply.. I might be looking at it wrong,, but I was thinking if I connected the 2 hoses that run to the shut off valve from the radiator side it would bypass the heater core..
While I was breaking in my engine and doing general mach up, I just ran a loop from the water pump to the intake. The two inlets are different sizes, but I had zero leaks just using regular hose clamps on the smaller port.
5/8 and 3/4 is correct. Just bought new ones last week.
or loop from pump to intake
or just pipe plug pump and intake
any of these work
It looks much better and don't have the extra hoses in the engine compartment that are not doing anything.
Plus it ensures there is no unwanted heat coming in from the heater core
My heater core was leaking so I disconnected the hoses from the engine and core and put plugs in the intake and water pump.
bypass heater core
I see how the bypass works on your later C3's. Where do you find the plugs for the intake and water pump and in my 68,there is a small tank on the fender where hoses go. The tank hoses have been 'looped' as the hoses are off the heater core ends. Little help Please Thanks
The fittings in the water water pump and intake are standard pipe thread. Depending on what type of plug you want, you can pick them up at a hardware store, or if you want something nicer, try a local parts place or Summit.
In my aluminum intake, I used the brass version. The plugs in the water pump are steel. All of them came from a local hardware store. You can see most of them in this photo...
Adam
Adam
Might work ok if you live in Alaska, but otherwise............Don't do it.
Received 2,686 Likes
Wrong
Aahhhh...sorry, that is not correct. The heater core is not a radiator.
