Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-05-2013, 07:54 PM   #1
cb98coupe
CF Senior Member
cb98coupe's Avatar
Default 1978 Courtesy timer location ????
I finally got out to my car to try to get to the timer for my courtesy light . I removed the interior of the glovebox . Nothing , I found nothing that resembles the timer anywhere behind there . WTF , I'm miffed . It looked so easy in the pics someone posted for me . This is typical for the way things go for me . I also took out the air duct on the passenger side .
cb98coupe is offline   Reply With Quote
Old 08-05-2013, 08:04 PM   #2
79vetter
CF Senior Member
On my '79 its right there where you described. I believe that it is orange in color and taped along the inner right side of the dash pillar. Maybe yours was removed?
I'll take a pic if you want...
79vetter is offline   Reply With Quote
Old 08-05-2013, 08:08 PM   #3
TimAT
CF Senior Member
TimAT's Avatar
77 it was taped to the harness right between the speedo and tach.
TimAT is offline   Reply With Quote
Old 08-05-2013, 08:22 PM   #4
KapsSA
CF Senior Member
KapsSA's Avatar
Quote:
VERY early 78 too.
KapsSA is online now   Reply With Quote
Old 08-05-2013, 09:52 PM   #5
cb98coupe
CF Senior Member
cb98coupe's Avatar
A pic would be nice . I don't think it was removed because the delay worked up until the lights would not turn off . I will look a little harder tomorrow but the pic would help greatly .
Old 08-05-2013, 09:59 PM   #6
CherokeeWarrior
CF Member
CherokeeWarrior's Avatar
On my 78 it is accessed by removing the glove box interior and it was on the right hand side on the pillar. It is a plastic box about 1.5 inches wide by 2 inches tall and about .5 inches thick if memory serves me correctly. At least gives you an idea of the size and location. I have no pictures when I replaced the circuit board inside the box.
CherokeeWarrior is offline   Reply With Quote
Old 08-05-2013, 10:14 PM   #7
cb98coupe
CF Senior Member
cb98coupe's Avatar
I am going to reach in there tomorrow and see if i can feel it . It is definitely not visible when you open up the glove box . Is the timer taped to the pillar or screwed down . I don't think I can do the job if it is screwed down . I really want to get this done . I am very frustrated . I am not the greatest at doing stuff but I thought I could handle this job . Thanks everybody .
Old 08-06-2013, 12:45 AM   #8
SciVette
CF Senior Member
SciVette's Avatar
On my '80 it is behind the glove box as well- orange plastic box about the size/shape of a deck of cards. Pretty hard to miss (unless of course the PO removed it). Good luck.
SciVette is offline   Reply With Quote
Old 08-06-2013, 01:15 AM   #9
desue
CF Senior Member
desue's Avatar
Is this it?
Under pass. side dash on my 79.
As you can see, I've got stuff under there that seems to be unplugged (Post on that coming soon)
Good luck!
desue is offline   Reply With Quote
Old 08-06-2013, 04:52 AM   #10
hunt4cleanair
CF Senior Member
hunt4cleanair's Avatar
Quote:
Seems I recall in 80's (81-82) its location was moved but can't recall exactly.
hunt4cleanair is offline   Reply With Quote
Old 08-06-2013, 08:17 AM   #11
cb98coupe
CF Senior Member
cb98coupe's Avatar
Went behind the glovebox this morning again . I felt around to the right of the glovebox and also by the a pillar , nothing . It has to be there because the courtesy feature worked until it started giving me a problem . I am gonna keep looking . I don't want to have to bring the car to a mechanic for this .
Old 08-06-2013, 08:20 AM   #12
cb98coupe
CF Senior Member
cb98coupe's Avatar
Quote:
Originally Posted by desue View Post
Is this it?
Good luck!
That's it . Where exactly behind the dash was it ? Everytime I try to do something easy , it's not easy . Story of my life .
I have all the bulbs out and let the car sit overnight and the battery did not drain so that's a plus . Started right up . When I removed the fuse the power antenna did not work .
Old 08-06-2013, 01:10 PM   #13
1978vett
CF Senior Member
Isn't there a way to jumper a couple of those wires to bypass the timer,, i can't remember whitch ones ..
1978vett is offline   Reply With Quote
Old 08-06-2013, 01:30 PM   #14
79vetter
CF Senior Member
Here's mine - its loose - not taped at the moment but its right there
Old 08-06-2013, 04:34 PM   #15
1978vett
CF Senior Member
Been trying to find my courtesy timer too,, Hadn't thought about taking the glove box out,, well I took it out and I found the timer, it had been disconnected and the connector was beside it.. Plugged it in and it works perfect.. also found a small round blue thing towards the back that says flasher on it.. I have no idea what it's for..
Old 08-06-2013, 07:02 PM   #16
cb98coupe
CF Senior Member
cb98coupe's Avatar
Man , I am going crazy over this thing . I even crawled underneath the dash and nada , nothing . I have an appt. friday with a mechanic . to try to figure out what the heck is going on . I will update when I have more news . There is a silver thing that looks like a flasher that I found . Oh well , thanks for all the replys .
Old 08-06-2013, 07:06 PM   #17
cb98coupe
CF Senior Member
cb98coupe's Avatar
My car was built 11/77 .
Old 08-06-2013, 07:24 PM   #18
cb98coupe
CF Senior Member
cb98coupe's Avatar
Here is the inside of my glovebox . Everything is pretty neat and doesn't look messed with . The round silver thing is the only thing I found .
Old 08-06-2013, 07:44 PM   #19
Willcox Corvette
Premium Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Willcox Corvette's Avatar
https://www.facebook.com/WillcoxCorvette
Send a message via MSN to Willcox Corvette
Initially GM had plans to put the timer behind the speedo tach housing.. you can view a picture of this in the Assembly manual on page 506 or section 12l sheet 9.
I've never seen a car with one back there.. they have all been located behind the glove box. On the 80 we just installed a dash pad in the timer was way around the corner and only visible if you looked from under the dash pad.
Click the image to open in full size.
Here is the 80 showing you in the right hand corner.
Willcox Corvette is offline   Reply With Quote
Old 08-06-2013, 07:49 PM   #20
1978vett
CF Senior Member
I found my courtesy timer and also the round blue thing.. Dont know what it is but it has a bracket around it that isnt fastened to anything..
Reload this Page 1978 Courtesy timer location ????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
