How many pumps?
Old 08-03-2013, 06:46 PM
Chicagodogs
Chicagodogs's Avatar
Default How many pumps?
How many pump the pedal before cranking over the motor? If you do, how many pumps?
Old 08-03-2013, 07:38 PM
4SPDL81
4SPDL81's Avatar
St. Jude Donor '16
Takes 4-5 when cold and has set for a week or more, none when warm...good luck!
Old 08-03-2013, 08:19 PM
79L824SPD
79L824SPD's Avatar
Yea, Same here. Seems like mine starts quicker if its been sitting a week rather than a few days.
Old 08-03-2013, 08:20 PM
DC3
DC3's Avatar
When cold, once all the way to floor to set the choke, then turn the key and it fires right up. That's when driving it every day. If I let it sit for several days, I have to pump twice then hold the throttle down about 1/2 way.
When warm, most of the time I don't have to pump at all but sometimes it takes holding the throttle about 1/2 way.
DC
Old 08-03-2013, 08:32 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
One cold and none hot.
Old 08-03-2013, 08:58 PM
'75
'75's Avatar
If the choke is set up properly, this works every time. If it's been sitting a week or longer it just cranks a few seconds longer. but no pumping.
Old 08-03-2013, 09:26 PM
68/70Vette
68/70Vette's Avatar
Never pump the gas pedal. I have an Aeromotive Street and Strip electric fuel pump. When I hit the ignition key position, the pump turns on and at the same time the starter turns over the engine. The engine might make a couple of rpm's but then it fires up.
Old 08-03-2013, 09:28 PM
Ironcross
Ironcross's Avatar
I just reach in through the window and turn the key and it lits right up....but its a FI Vette
Old 08-03-2013, 11:39 PM
kdf1986
kdf1986's Avatar
maybe 3 pumps. But I drive it every Friday to work. So it sits for 1 week. At work, I only have to pump it 1 time.
kdf
Old 08-04-2013, 12:46 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
One....just to set the choke and pump some fuel in the intake. Wait 3 seconds and start it. If you need to do more than that, you don't have the choke set up right...or the accelerator pump isn't working properly...
or you have a Holley!!!!
Old 08-04-2013, 06:36 AM
scottw
scottw's Avatar
Street Avenger. One pump to set the choke, turn key, fires right up. Every time.
Thanks to lars setting up the carb for me.
Old 08-04-2013, 06:41 AM
Haggisbash
Haggisbash's Avatar
One pump, full choke (manual choke) when cold fires move immediately to 1/3 choke, Holley carb.
Old 08-04-2013, 08:13 AM
7T1vette
7T1vette's Avatar
OK, OK.... that was an attempt at humor -- not a vendetta against Holley carbs.
That's the way all carbs should work, anyway.
Old 08-04-2013, 10:09 PM
Mod75
Mod75's Avatar
Finalist 2021 C3 of the Year - Modified
Have manual choke but don't use it, cold 2 pumps, hot nothing.
Old 08-04-2013, 10:48 PM
kwplot34
kwplot34's Avatar
pump it twice, wait about 5 seconds,turn the key and it fires right up. even after sitting for several weeks. And i dont even have a choke on my carb.
Old 08-05-2013, 08:43 AM
Redwing01
Redwing01's Avatar
2015 C3 of Year Finalist
2 here as well. Fires up every time.
Old 08-05-2013, 09:45 AM
Dustup7T2
Terrorizing Orange Cones
Support Corvetteforum!
Dustup7T2's Avatar
I mounted a chokeless Demon double pumper on mine. Same basic design as a mechanical double-pumper Holley. Fed by a factory-style mechanical fuel pump and 10 degrees of initial timing on a Comp Cams Magnum 292.
1 pump cold and lightly feather the throttle after start to clear its throat. Part throttle to none warm, gets mine back to idle.
Old 08-05-2013, 12:28 PM
Chinaski
Chinaski's Avatar
St. Jude Donor '14
Twice when cold, none when warm.
Old 08-05-2013, 02:36 PM
jcloving
jcloving's Avatar
cold: one pump before I turn the key, one while I turn it to start. It turns over for maybe 2-3 seconds and then fires up.
hot. just turn the key and it roars to life
To How many pumps?
Quick Reply: How many pumps?
