1969 Driver Side Wheelhouse Interior Panel Help - threaded insert repair kit?
My threaded inserts are missing, anyone make a repair kit for this? should I open it up, epoxy nuts into it?
I appreciate any help, also would buy a good used panel if anyone has one with ALL 4 threaded inserts intact and threads that are perfect.
Thanks, Tim
Thanks, Tim
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yeap.. and usually when they are missing they take some meat out with them. Good epoxy will cure that when you put the new insert in there.
http://willcoxcorvette.com/product_i...ducts_id=26949
Former Vendor
Willcox
ordering the kit from your site now
mine were missing, once kit comes I will drill them to accept the new inserts then epoxy them in place with Devcon Plastic Welder which works unreal on fiberglass/plastic interior panels
Holy Crap Wilcox !!!!
$23.87 to ship a small pack of screws to Canada?
I paid less for an entire Parking Brake console.
And you said you USPS calculator was fixed on your home page.
Had to fix one or two in mine as well. I used threaded inserts - something like these
http://www.grainger.com/Grainger/EZ-...B66?Pid=search
Bought them at my local Ace Hardware - less than $1 IIRC
Jim
Jim
Eljay, we are talking about the screws that hold the inner rear quarter panel. To get that panel off you have to remove the trim plate that is inside the door jamb. Problem is these screws rust and won't come out, you have to drill the heads off to remove the inner panel (see my pictures above, my car is purple, the existing screw was painted to match the door jamb).
Rather than spend 50.00 for 8 screws and nuts, I am headed to my local hardware store at lunch to pick up an GraBit set to remove the broken screws myself. If this doesn't work, there is a local supplier for the parts 70BBvert posted for $17.00.
Just a bit of advice to all, I am installing ALL my screws with anti-seize to ensure this never happens again.
Ken
Ken
yeah I could have got inserts and made them, but I like how these inserts have a bottom so that epoxy wont ooze in when I glue them in place, plus have the rough edge on outside to help them bite and will be the correct overall height, to me worth the 29 bucks...and 8 bucks to ship...as far as I know, when you order from Willcox their automated shipping on the website is way off and they correct for it and credit you back, my shipping was going to be like $15, turned out to be $7.95
