Arm rest pad
Old 07-16-2013, 07:07 AM
JoelH
Cruising
JoelH's Avatar
Default Arm rest pad
How does the arm rest pad on the door attach? I see you can buy replacements that have double sided tape. I have one in good shape but it's loose. Can I just pull it off and tape it down or is that screws involved? Thanks.
Old 07-16-2013, 07:49 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
The tape loses strength after a while. Clean up the old tape and install new.
Old 07-16-2013, 07:54 AM
gbvette62
gbvette62's Avatar
Received 2,029 Likes on 1,315 Posts
All of the door arm rest pads, are replacements. The factory panels never used the pads. They were created by the aftermarket, to cover cracked original panels.
I'm pretty sure they were always designed to be installed, using double sided tape. You should be able to just pull them off, but if the original panels are cracked underneath, you may break loose some of the old panel skin. If your going to try to remove them, I think I'd try using a putty knife and heat gun, and go slowly.
JoelH
Cruising
JoelH's Avatar
Easy. Thanks!
To Arm rest pad
Quick Reply: Arm rest pad
