Convincing argument to stay stock
Or close to it. I see post after post from owners fighting problems related to "upgrades" to their Corvette. From battery drain problems to electrical problems to ignition problems. It makes me think Lars and grumpy Canadian Mike Ward are right. Leave em pretty much stock and just fix the stuff that breaks. I'm no NCRS advocate by any means but a lot of "improvements" on these cars do nothing but.
Received 3,043 Likes
St. Jude Donor '05
Except for my DD which will always be stock I am a die hard modder;addicted to the sensation of being pinned in the seat.....like hard. Where drag radials still spin its a religious thing lol.
True though the most reliable the car will be is when its bone stock.
Yes boring and slow but reliable.
Agreed. I'm all for mods that make sense not just bling. Some quality aluminum heads, intake, cam. Some bigger wheels that get you to some true performance tires. Tires make a huge difference in how a car rides and handles. A lot of these suspension mods i'm not buying for a street machine. If you're tracking your vette that's a whole new ballgame. Otherwise you're wasting your money. I'm going to stick to my stock distributor and points. Heck that's part of owning one of these beasts. No computers. Simple electronics. So i have to change the points and set dwell. Big deal. Same with the quadrajet.
.............................STOCK*.................CURRENT
HP.........................180..........................400
WEIGHT (lbs).........3600.......................3400
REDLINE (rpm).......5300........................6500
1/4 mile ................16 sec @ 85-90.......12.8 @ 108
Handling ................not great................. 1.0+ g's
* Approximate values - couldn't find consistent numbers
I have no idea why I modified mine . If you have something special I agree keep it stock, but I wouldn't put my "rare" white 76 back to stock for anything. More dependable now and the performance is not comparable.
But like this arguement usually goes, its your car do with it what you want. You can't take it with you when your gone anyway.
Lots of times the upgrades are as cheap (at first) as going back to factory original. Example is buying a stock as a stick crate 350. Dead on reliable, no hassle and many times with a warranty. Not much more cash and a 383 appears in it's place.
I wouldn't go fooling around with a documented 69 L-88 car, but I wouldn't be driving it much either.
You have to remember that by the mid 70's GM wasn't trying to satisfy the driver. They were trying to satisfy Ralph Nader, the NTSB and the EPA bureaucrats. I like to think that any modifications that aren't absolutely insane are keeping in the spirit of the car. I have different heads, cam, exhaust, etc in my car. When people tell me, "You're really not building an '80" I tell them "I'm building the '80 that Chevrolet should have built."
By the way, I would drive the tires off an L-88.
My '68 L36 Roadster is as rodded as its gonna get. And it's pretty stock.
One thing, a roller cam in the ol' 427 sounds good.
Then the pan could leak Mobil1 instead of Rotella T...
Why would anyone read or post in the "Tech/Performance" section of the forum if they prefer their car "stock"????
OK, maybe just for the "Tech" part...
Stock for me is very boring. Even the LT1 that I started with was very slow compared to today's standards and. I quickly became bored with it. After all the. l48 is the same motor you could get in any V8 Chevy. The suspension was just so so. If you just want to drive a Vette to have one and drive then keep it stock. If you want to drive the heck out of it and push it to the limits mod the heck out of it. I prefer mine modded.
reasons to mod.
got busted on by a V6 mustang
can't get rubber in 1st much less 2nd,3rd or 4th
wife laughs at me when she rides in it
up side of that last one is that she can't complain when I spent money on it.
Well my point was mods that don't do a thing for performance. Unless you're tracking or pushing your vette to the limits on the street all this coil over and suspension bling is a waste of money. I bet the vast majority of owners do neither. Bigger wheels as in 17" that get you to better performance tires will do wonders to how a C3 handles. Lars proved all the bling ignition systems don't add 1 single horsepower to any vette engine. If you like them because you don't want to mess with points so be it but all the claims of performance gains were proved total bs. As for engine mods? NOW you're talking. It's the heart of the beast and horsepower is everything.
I actually bought mine because it wasn't original.... takes the guilt out of modding a classic so I can really enjoy it guilt free.
I agree the colorful ignition wires and fancy plugs don't do much of anything.... some of the controllers do a lot for higher rpm applications to reduce scatter. platinum plugs do last longer I have found. Suspension upgrades do improve things.... coming from an 84 z51 the 74 feels more like driving a pickup truck than a sports car as far as handling... I don't mind it too much since I'm going to be using mine as a street car and not racing or hitting the drag strip.
As parts wear I always up grade! Ever older than 82 vette I've owned was in desperate need of horsepower! Its pretty sad when you vette can't even break the wheels loose
The bolt on aluminum heads can't be beat,plus a cam and you got a great street runner that looks stock
If I had an unlimited budget, I would have more hp AND be getting everything else in order.
As it stands, I have a limited budget, and enough experience to know that any upgrades have to be done in-tandem with other upgrades in order to be truly satisfying. My base-engine '71 is engineered as a system, and everything on it works very well; it starts and warms up nicely, it idles smoothly, and I have enough power to keep up with traffic. And when I'm out cruising the back-roads, it's easier for me to keep out of trouble with less reserve HP on tap than, say, a big-block would tempt me with.
I know slapping a $400 Holly carb on an adapter on top of my stock intake is not going to make anything better, and that if I take it down as far as removing the heads, I may as well take the whole thing out and stroke it to a proven aluminum-head combo.
But honestly, I'd rather spend my meager funds getting the A/C going, or making the radio audible.
St. Jude Donor '05
good stuff. modding is a slippery slope I always slide right to the bottom and am working on it non stop for yrs to come.
Agree on the ignition.
I regret getting the MSD with the box etc. The dist is made of crap and assume one dya the box will leave me stranded. When it does an HEI will be in there. I had one of the pricier makers wires burn up on a header so in a pinch used a cheap set of $27 wires from Oreillys to get me by runs exactly the same.
