68 Convertible - New Glass Windows
The windows in my 68 have chip marks on the top of the windows where the windows used to contact weather stripping mounting screws on the hardtop. There was violent shaking with the hardtop on the car and so the impact and chipping to the window glass. It's always annoyed me since 1972 when I bought the car!!!
I bought used window glass on eBay a few years ago. Looking to install these windows, I realized that the windows are scratched and have wear sections in the glass where the door/window seals contacted the glass. The scratches are pretty much microscopic...you have to hold the glass up to the sun light at a particular angle, but when you do you can see them plainly.
I can buy a pair of new window glasses for about $650. These are reproductions, not NOS. I have no clue if they are manufactured with original factory tooling or if they are just some inaccurate repro's. I have Googled this and one Corvette magazine reported buying "new" window glass to install and didn't report a fit problem.
Anyone bought "new" 68 Corvette window glass? How did it fit. The factory 68 window glass was installed in all 68's and early 69's. It has eight holes drilled in each window pane along the bottom. The late 69 and up factory glass five holes per window pane along the bottom.
Becoming sensitive about window glass scratches, my 08 Corvette with 9300 miles on it has two closely matched microscopic parallel scratches on the passenger's window. They are about 45 degrees to horizontal and about 4 inches long. Maybe a women's diamond ring?
Two things I've heard.
Repo's seem to be thinner, this may have been corrected by now though.
The other is that if you can run your fingernail over the scratch and not catch it, you should be able to polish it out. I think Eastwood makes a kit.
I'd keep my originals if possible.
I'm Looking for 1969 conv. door glass now. I have a buddy that installs glass for a living. He recommended PGW OR PINKERTON goggle these two companies. He said they fit the best and some of the cheaper ones don't fit at all. I hope to order mine next week. I will update once I get mine.
Received 1,469 Likes
Cruise-In II Veteran
Is future judging a concern for you? Original glass is coded and dated; both are judged.
I'm only a purist to the extent the interior is stock (except for 69 head rests) and the exterior is stock, except for the 69 factory side exhausts. The engine is a ZZ4 driving through a TKO-600 five speed. Thanks.
Received 2,878 Likes
Hi 68/70,
I believe ALL auto glass sold in the U.S. needs to have the manufacturer's identifying info on it.
On your present glass look for a VERY lightly etched logo and date code on the bottom rear of the door glass right above the door lock flapper.
If you decide to pursue new glass consider glass from Auto City Classic in Minnesota.
Regards,
Alan
Regards,
Alan
Does anyone know if the green tinted glass from autocity glass is the accurate tint color? I only need one side and I would be concerned about the tint matching.
Thanks, Craig
Thanks, Craig
Mark
Thanks to all of you!!!! I'll follow up on the autocityclassic website that was cited.
I'll give a call for the windows. I was looking at their website, looks like a new windshield for my 70 is $339. I think I'll buy one while they're still available. It's windshield has scratches from wipers losing their rubber. That's one of the VERY FEW defects that car had that I knew about when I bought it.
My head rest story: I wanted to get head rests as a safety issue in case I ever got rear ended. The seat backs need to have the head rest shaft receptacle. I bought a set of 69 seat frames on eBay and used the seat backs for my intended head rest. Typical for eBay, they arrived in worse condition than the picture...they were rusted. I soaked them in a vinegar bath to de-rust them, and then repainted them. Next, to get the seats on their way to Al Knoch, I took them to him when he was at the Pomona Fairgrounds. They went back to his El Paso facility for recovering in leather and to have the head rests added. Al had just recently, at that time, obtained the original factory molding that made the 68/69 headrests, so I have a set of new headrests. The interior shaft of the head rests was from a head rest set I bought on eBay and sacrificed. It's the medium bright blue interior
As long as I raving on about the seats, might as well do the seat belt story. Apparently only 35 68 Convertibles had shoulder belts. I sent my 68 lap only seat belts to Snake-Oyl for reconditioning and requested the shoulder belts also. After parting ways with $800, I received duplicates of the factory 68 lap and shoulder belts. Just to make a long story shorter, the 68 shoulder belts are not practical...they don't have retractor reels, so when you put them on tight, you can't lean forward to look in the door mounted rear view mirror. If you concern is practical shoulder belts, you have to go to the 69 system...but the 69 system doesn't really look right in a 68.
Thanks again
Thanks again
