Dexron 2 or Dexron 3 in 1976 Corvette?
Old 05-09-2013, 09:59 AM
Ryjba
2nd Gear
Ryjba's Avatar
Default Dexron 2 or Dexron 3 in 1976 Corvette?
I am changing ATF in my 1976 Corvette. The operators manual says Dexron II and that I would need 11 us qts or 9.25 imp measure qts.
My question is can I use Dexron III?
How much ATF can i expect to use as i am pulling the ATf pan and filter and not sure how much will remain in the system when i drain it
Thanks in advance
Old 05-09-2013, 01:40 PM
David Mc
David Mc's Avatar
New Dextron supercedes old Dextron. I doubt you can still purchase Dextron 2 or even 3.
An empty transmission needs 11 quarts.
3 1/2 - 4 quarts for a filter change
Old 05-09-2013, 06:45 PM
qwank
qwank's Avatar
Try to find dex 3 if possible. Dex 6 will work but it is a lot thinner and if you have any current transmission leaks they may leak more with dex 6
Old 05-09-2013, 09:32 PM
bpassmore
bpassmore's Avatar
I'm using Dex 6 in my '82 and 04 blazer. The big difference is synthetic, supposedly shifts more positively, and runs cooler.
My '82 had 50+K miles when I changed over, no problem 58K on it now, 38K on the blazer fluid. The stuff doesn't change color. I did have the fluid analyzed for wear every 5K miles for 3 or 4 times on the blazer, don't do it now, did not indicate any wear.
Old 05-10-2013, 10:20 PM
Ironcross
Ironcross's Avatar
You can use all the fluids except possibly the synthetics...Performance transmissions shift best with Tye 'F, which is actually Ford fluid and make for hard positive shifts...same stuff for a power steering unit.......just a different color
To Dexron 2 or Dexron 3 in 1976 Corvette?
Quick Reply: Dexron 2 or Dexron 3 in 1976 Corvette?
