Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-05-2013, 08:10 AM   #1
78SilverCam
CF Senior Member
78SilverCam's Avatar
Default Brake Line nut rounded off
Good morning all,
I'm installing new calipers/rotors/brake hoses and discovered that the brake line nut on the front right wheel has been rounded off. I've tried to work around it, and did more damage than good.
Anyone else have experience with this? Grind off two sides and try again? Something else?
Thanks for your input.
78SilverCam is offline   Reply With Quote
Old 05-05-2013, 08:17 AM   #2
bobbarry
CF Senior Member
bobbarry's Avatar
I've always had good luck with a vise-grip and heat at the threads. Lock it on TIGHT, with the serrations grabbing hard into the nut, and tap the handle of the vise-grip with a ball-peen to shock the nut (steady pressure can just round it off more).
You'll ruin the nut, but you've already not got replace it anyway.
bobbarry is offline   Reply With Quote
Old 05-05-2013, 08:32 AM   #3
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Vise Grips applied judiciously.
Easy Mike is offline   Reply With Quote
Old 05-05-2013, 09:27 AM   #4
Chinaski
CF Senior Member
St. Jude Donor '14
Chinaski's Avatar
Quote:
That's what I did.
Chinaski is offline   Reply With Quote
Old 05-05-2013, 09:32 AM   #5
Garys 68
CF Senior Member
Vice grips, but if it's that bad you might as well cut it and replace that line.
Garys 68 is offline   Reply With Quote
Old 05-05-2013, 09:46 AM   #6
billcarson
CF Senior Member
billcarson's Avatar
make sure the vise grip has a curved jaw.
billcarson is offline   Reply With Quote
Old 05-05-2013, 10:09 AM   #7
78SilverCam
CF Senior Member
ulgh, Im hoping to salvage what I can - replacing the line looks like it could be really easy or really annoying. My experience is given the option - its always annoying.
For instance - remove the rivets. Sounds easy...these things won't budge. (rotor off, just cant get them out of the hub.)
Old 05-05-2013, 10:34 AM   #8
Chinaski
CF Senior Member
St. Jude Donor '14
Chinaski's Avatar
Everything is annoying when working on these cars. It's the proverbial "Can of Worms" everytime.
Old 05-05-2013, 11:16 AM   #9
Bagpype
CF Senior Member
Quote:
Couldnt have said it better. I started with a simple pad change on mine. I rounded one nut off like you. One thing led to another and that pad change turned into new calipers all the way around, new pads, all new brake lines, new master cylinder. Fun. I got my rounded nuts off with this http://www.lowes.com/pd_314851-281-1...ers&facetInfo= I got the smallest one I could find. The rounded nuts came off perfectly with these pliers..
Bagpype is offline   Reply With Quote
Old 05-05-2013, 01:09 PM   #10
7T1vette
CF Senior Member
7T1vette's Avatar
If you can break that fitting loose with a Vise-Grip, you can tighten it back up with the Vise-Grip. Having a rounded-off fitting should not cause you to change a brake line, if you don't want to.
Buying a good quality (Snap-ON) tubing wrench would have been a good investment so that you would not round off the fitting. But, as that is a missed-opportunity, just re-install it "as is".
7T1vette is offline   Reply With Quote
Old 05-05-2013, 01:22 PM   #11
Bagpype
CF Senior Member
You can put it back on but using the "it came off like that, it will go back on like that" logic is not something you should be using on a Corvette. Unless you don't plan on ever touching that brake line or having anyone else touch it either.
Old 05-05-2013, 01:33 PM   #12
billcarson
CF Senior Member
billcarson's Avatar
bagpype i know what you are saying and i agree but sometimes we all cheat a little as it gets expensive and time consuming to replace everything.also some after market stuff is complete garbage.check out this ac delco boxed brake hose.it had sunsong written on it.
Old 05-05-2013, 01:42 PM   #13
Bagpype
CF Senior Member
I understand and completely agree with you. Having said that, I absolutely would not cheat anything involving the brakes.
Old 05-05-2013, 02:56 PM   #14
7T1vette
CF Senior Member
7T1vette's Avatar
There should be no problem tightening that fitting so that it won't leak. If so, the fact the fitting is 'rounded off' will have NO EFFECT on the brake system.
If the OP cared about the fact the car was a "vintage Corvette that should be handled with kid gloves", the OP would have used a better tool in the first place (like I recommeded...after-the-fact). As he rounded it off to start, putting it back on that way should not be an issue, IMO.
But, thanks for your attempt at teaching me some better "Corvette manners"....
Old 05-05-2013, 03:18 PM   #15
Bagpype
CF Senior Member
If you read the OP's post he says he discovered it was rounded off. This, one would have to assume was that way prior to him even putting wrench one on it. Also, we can deduce that it was probably put back on like that by someone who didn't want to fix their car right, or for lack of a better term, lacked "corvette manners". Had the previous owner done it the right way, as I merely amicably suggested, then we wouldn't be posting on this thread and 78silvercam would have been able to do his brakes. The right way...
Old 05-05-2013, 03:54 PM   #16
7T1vette
CF Senior Member
7T1vette's Avatar
Why do I suspect that not everything on your car is "perfect" either?
Old 05-05-2013, 04:30 PM   #17
oldschoolvette
CF Senior Member
oldschoolvette's Avatar
Quote:
+ heats and mechanically massage
oldschoolvette is online now   Reply With Quote
Old 05-05-2013, 05:35 PM   #18
arklacat
CF Member
I used a small pipe wrench. I could only find a 10" locally. An 8" or 6" would have been better. I didn't want to wait for the ups truck.
I applied a bit of heat to the hose side but I don't think that really mattered. I ended up ordering all new lines and that same line was stuck in the combo valve. The pipe wrench broke it free without any heat and did very little damage. I had soaked them pretty good with pb blaster.
edit: i tried two different vise grips, trying to work the nut back and forth. they just rounded the nuts more.
arklacat is offline   Reply With Quote
Old 05-05-2013, 06:35 PM   #19
john 72-04
CF Senior Member
john 72-04's Avatar
Man...... I've never seen someone who likes to try and start arguments as much as you. The OP says he found it that way when he went to do the job. Oh and by the way it's not a tubing wrench it's a flare nut wrench.
john 72-04 is offline   Reply With Quote
Old 05-05-2013, 07:31 PM   #20
billcarson
CF Senior Member
billcarson's Avatar
john 72-04, really i have.seriously though he has helped me in the past with his suggestions and when you start posting for a few years you might get a little sharp with your comments.try and give the long time posters some slack,they have helped many guy's over a long period of time and deserve it.
Reload this Page Brake Line nut rounded off
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Quadrajet fuel filter nut stuck, now what? rene040269 C3 General 15 08-14-2013 03:30 PM
Rotted Cotter Pin - Remove nut? robbiewolfer C3 Tech/Performance 5 08-01-2013 09:06 AM
rubber brake line R&R Questions Impala Balko C4 Tech/Performance 29 07-04-2013 03:03 PM
Rotor Removal - What's the secret? Larry N. Johnson C1 & C2 Corvettes 41 12-25-2012 06:18 PM
69 Brake caliper removal richardttu C3 Tech/Performance 21 07-11-2012 02:41 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
