Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2013, 10:43 AM   #1
The Punisher
CF Senior Member
The Punisher's Avatar
Default Coil spring adjusters
Do they work? The type I am referring too is the ones you clamp to the coil and it compresses it.
The Punisher is offline   Reply With Quote
Old 05-04-2013, 11:08 AM   #2
jesse10886
CF Senior Member
jesse10886's Avatar
Jimmie Bussart
Idk good question though I am interested in opinions and real experiences who had them? I would think that the spring is set to safely work at one rate of compression based on the vehicles weight. Is compressing it going to change its reliability or stability and make it unsafe?
jesse10886 is offline   Reply With Quote
Old 05-04-2013, 08:41 PM   #3
gcusmano74
CF Senior Member
They might work, but, IMHO, they are not a good idea.
My 2 cents, don't.
You might need to cut a bit off the spring, or get another one.
gcusmano74 is offline   Reply With Quote
Old 05-04-2013, 08:59 PM   #4
MakoJoe
CF Senior Member
I do not like the idea of compressing the springs to get a stiffer ride or cutting out a section of the spring. Your best bet is almost always to get a performance suspension spring set. Depending on your year Vette this will lower the suspension between 1/2 to 1 inch. You will need to get an alignment after installing a kit like this because it lowers the car and changes the dynamics of the suspension.
Such as this to improve the handling of the car. It is fairly inexpensive and a better solution.
http://www.ecklerscorvette.com/corve...1963-1979.html
MakoJoe is offline   Reply With Quote
Old 05-04-2013, 09:24 PM   #5
3JsVette
CF Senior Member
3JsVette's Avatar
There is no guarantee that buying front springs to lower the ride height is going to put the stance exactly where you want it to be. While I agree the spring compressors are a bad idea buying higher rate lowering front coil springs could still need to be trimmed to get the look you're after. Unless you do something like coil overs or stock car type hidden ride height adjusters it could be trail and error.
3JsVette is offline   Reply With Quote
Reload this Page Coil spring adjusters
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
