Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-30-2013, 01:20 AM   #1
razman
CF Senior Member
razman's Avatar
Rick Spear
Default quick question about turn signal/hazard flashers 68'
on my 68' i have one flasher unit that plugs into the fuse box (for turn signals i presume) and a second flasher under right hand dash panel (for the four way hazard flashers i believe. anyway, my turn signals work fine, but hazards come on but won't blink.....seems like someone once told me that the second flasher under the dash is a different type than the one that goes in fuse panel...??? anyone know about this, i believe i have 2- #552's now...Rick
razman is offline   Reply With Quote
Old 04-30-2013, 04:01 AM   #2
my 76 ray
CF Senior Member
my 76 ray's Avatar
The flasher at the fuse box is for the four way hazzard flashers. The one under the passenger dash is for the turn signals.
my 76 ray is offline   Reply With Quote
Old 04-30-2013, 05:57 AM   #3
terrys6t8roadster
CF Senior Member
terrys6t8roadster's Avatar
you are correct, two different flashers. turn signal used a 536 which would stop flashing when a bulb was out.
terrys6t8roadster is offline   Reply With Quote
Old 04-30-2013, 04:27 PM   #4
razman
CF Senior Member
razman's Avatar
Rick Spear
so i should have a 536 at the fuse box for the hazards then?? thanks you guys...Rick
Old 04-30-2013, 06:48 PM   #5
loup68
CF Senior Member
Support Corvetteforum!
I thought that they were the same too, but ZIP lists two different ones. Lou.
loup68 is offline   Reply With Quote
Old 05-01-2013, 04:32 AM   #6
terrys6t8roadster
CF Senior Member
Quote:
I use the same one for the four way in the turn signal . even if one bulb burns out the rest keep flashing but then you need to check periododicoly. did I spell that rite?
Old 05-01-2013, 04:53 PM   #7
razman
CF Senior Member
razman's Avatar
Rick Spear
Quote:
no, you didn't..LOL, who cares?? but thanks for the info, i put two of the same kind in, and everything works fine, will just have to keep an eye on the bulbs...(periodically) Rick
Reload this Page quick question about turn signal/hazard flashers 68'
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Turn signal flasher location coop51 C3 Tech/Performance 25 10-23-2013 11:35 AM
Turn Signal Issue kjohn C4 Tech/Performance 0 10-03-2013 04:16 PM
C2 Hazard Flasher--help Martyt C1 & C2 Corvettes 6 06-19-2013 04:25 PM
'68 Turn Signal Woes... Tracknod C3 Tech/Performance 11 12-10-2012 09:27 PM
What is the dumbest engineering feat you've experienced on your car. Sxrxrnr C1 & C2 Corvettes 38 09-21-2012 08:49 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
