How fast is too fast?
Old 04-18-2013, 08:55 AM
rafalc
rafalc's Avatar
Default How fast is too fast?
My 70 4-speed has a 3.7 rear which spins at 3000RPMs at around 62-63 mph. I'm not used to driving in the right lane on the highway but I also don't want to push it too hard and drive too long at 3k.
Question is .... how far do you guys push your RPMs and feel safe driving at those speeds over longer distances? Am I just paranoid thinking I'll destroy the motor going any faster than 65mph and over 3k rpm?
Old 04-18-2013, 09:01 AM
MrJlr
MrJlr's Avatar
My '74 runs 3500RPM at 70MPH.....
I'd run it all day like that.....No problem at all.
Old 04-18-2013, 09:41 AM
oldschoolvette
oldschoolvette's Avatar
I would say as hard as your wallet will let you
don't worry about the engine, its your wallet from the gas bill that will be the victim here
Old 04-18-2013, 10:19 AM
Vette5.5
Vette5.5's Avatar
I know what you're talking about, as have a car with a 3.73 axle, and didn't like like high rpm highway driving. Changed the tranny out to an od unit, and much more confortable now. This has been talked about before, with many saying don't worry about engine damage. However friend of mine took his 396 Chevelle 4.11 accross country at highway speeds, and never ran the same after that.
Old 04-18-2013, 10:45 AM
texas jim
texas jim's Avatar
Default If the hi-way driving
Yes, feels uncomfortable f/ the driver, but not terrible f/ a SBC that's in proper operating condition. If you drive the car on the hi-way everyday and very often, then install smaller gears, ie; 2:80s or 3:20s. If it's just a once in awhile thing, then leave the existing gears in there. I personally wouldn't have 3:70s in a car that I drove on the hi-way very often. I don't like the feel of a SBC spinning at 3 grand on a regular constant basis. I'd install something that let me run at about 2300 rpms when at 70 or 75 mph. If you only run the car on the hi-way now and then, just leave it the way it is. Good Luck.
Old 04-18-2013, 10:50 AM
spot99
spot99's Avatar
Testify!!
Old 04-18-2013, 01:15 PM
cottoneg
cottoneg's Avatar
Depends, my old stock 350/350 motor had forged pistons, heat treated connecting rods and forged cranks. They could live all day at more than 3K.
A new strong motor, should take more. On track, you take it to redline all the time.
Old 04-18-2013, 01:21 PM
rafalc
rafalc's Avatar
Im concerned about an occasional drive to work and back....30miles each way on the highway going over 3k the entire way. Just wanted to see how others feel about it with more mechanical/motor experience than me.
calwldlife
calwldlife's Avatar
St. Jude Donor '22
I have the same concerns.
3k cruising looks
Old 04-18-2013, 01:50 PM
MAXCO
MAXCO's Avatar
Mine runs 3500 rpm at 120 km/hr (75 mph) and I drive twice a year to Mosport about 2 hours away with no problems. Is it annoying running high rpm the whole way?? Yes...will it hurt a good running motor?? No. If this was my daily driver and I drove highway everyday I would change gears or tranny but for occasional highway driving just have fun and enjoy the ride.
Old 04-18-2013, 11:45 PM
BeansWorld
BeansWorld's Avatar
I feel the same, driving around 3K RPM at 65 MPH makes me a bit uncomfortable (1970 454 4-speed). I'm looking into changing to a 5-speed manual for the long cruises to the beach and back home to show off in Pittsburgh.
The rebuilt engine is strong, but gas mileage suffers a great degree. I already have the factory trans in storage so replacing the current installed Richmond is no big deal. I may never see the cost benefit, but I'm a cruiser these days and the highway will serve as an important part of my destination.
Old 04-19-2013, 12:13 AM
Solid LT1
Solid LT1's Avatar
2 words:
FIVE SPEED!
End of discussion
Old 04-19-2013, 02:07 AM
Ironcross
Ironcross's Avatar
My ratios in the toys are from 4.1 and 4.56.....they use to travel 500+ miles a week end from Dearborn to Boyne and back at 3500 RPM`s and above on U.S.75....with the 4.1, 3500 is 70MPH and the 4.56, 70MPR is 4000RPM`s....Built right, you wont have any worries as I know I dont and they are all the highest advertised HP available either BB or SB......
Drive it, thats what there for.....they are tougher than you think.....
PS, 3K is nothing...run all day long
Old 04-19-2013, 04:20 AM
Danish Shark
Danish Shark's Avatar
3k is high idle for a Ferrari engine
Old 04-19-2013, 04:29 AM
MrJlr
MrJlr's Avatar
I'm telling ya...unless yer L48 is a POS....you're ok.
They were meant to run.
Old 04-19-2013, 07:57 AM
scrappy76
scrappy76's Avatar
If ya think about it, back then when most these cars were built, the speed limit was mainly 70-75 on the highway and all the most were only offered in the higher gear range with the autos or manuals. They are built for it. I think for most its the annoyance of the high rpm sound. I drove my 350 with 3:73 gears for almost two years daily to work and kept it about 3k. Now I am running the bigblock the same just not as often because of gas milage.
Old 04-19-2013, 08:19 AM
71scgc
71scgc's Avatar
We've all gotten too used to OD.
You wouldn't have flinched at those revs in 1970.
Carter
To How fast is too fast?
Old 04-19-2013, 08:22 AM
rafalc
rafalc's Avatar
Good to know, thanks for the feedback. Now I can stay in the left lane where I belong
Old 04-19-2013, 01:56 PM
Mid-Years Forever!
Mid-Years Forever!'s Avatar
Carter
Yes, we have, but you make that sound like a bad thing.
I share the OP's concerns.
I like the idea that OD can reduce:
1. Wear and tear on the mill.
2. Noise. (I like headers & pipes--I don't like D-R-O-N-E, for 6 hours, one way).
3. Gas consumption.
I've seen mention of both Tremac and Richmond trannies, in both 5 and 6 speeds. I like to shift, so I'd like a 6 speed.
My Questions:
1. Cost of Tremac 5spd conversion? 6spd? (Parts only--my labor).
2. Cost of Richmond 5spd conversion? 6spd? (Parts only--my labor).
3. What 5spd is in early '80's Z28's? I read (here) it was a Tremac, and that buying a rusted out Z28 for hundreds of dollars would be, by far, the cheapest conversion. Discuss?
4. When doing these conversions, are new cross members available? And I'm guessing I get to drill new holes? Or are the cross members engineered to use the existing holes in the frame.
Thank you.
Old 04-19-2013, 02:07 PM
srs244
Support Corvetteforum!
srs244's Avatar
St. Jude Donor '09-'10-11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
my 78 runs at approx 3200 rpm at 70 and i cruise there or a bit higher for hours without any concerns. i would just make certain that if you are running an original engine or a rebuild to original specs that you use a good, zinc rich oil for the flat tappets in the block. personally i have been using joe gibbs HR2 10-40 ever since the rebuild of my engine 2000 or so miles ago and other than a distributor module failure at about 600 miles it runs like a top and will cruise all day at high speeds. i'm sure you rev it loads higher taking off or going through the gears, so why be afraid of a constant 3-4000 rpm ride? if on the other hand you are running a tired engine, you could experience a problem at 2k just as easy as you could at 3 or 4k rpm. corvettes were designed to be driven (even those that were made strangled in the 70's) so drive it and enjoy it.
Quick Reply: How fast is too fast?
