vinyl wrap
Old 02-03-2013, 11:50 PM
taylor34
Support Corvetteforum!
taylor34's Avatar
Default vinyl wrap
Hey--
I saw a thread on this about 1 1/2 years ago in this forum but no one had ever tried doing it to a c3 at that point. My question is, has anyone tried it now? My 72 has a deteriorating paint job up front, basically it needs a repaint but that's probably 3 years away I'm guessing due to the 5k to 10k price tag. I had forgotten about the vinyl wrap diy option until today, and it looks like they've got some nice colors that would work. But before I would even attempt to undertake something like that, I'd like to know if anyone else had ever took a shot at it. Thanks
Old 02-04-2013, 12:22 AM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
I saw an episode of "How Do They Do That" not too long ago where a Union Jack wrap was applied to a Lotus Exige. Don't recall the cost, but I'd think a C3 shouldn't be any more difficult for a real pro shop.
Old 02-04-2013, 08:28 AM
diehrd
diehrd's Avatar
I think wrapping a c-3 would be pretty str8 forward , except the rear deck and quarter panels , there you will need one real big section of wrap because there are no breaks in the surfaces. Well at least on my 1980 there are not any .
Old 02-04-2013, 12:09 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
I put a wide vinyl stripe on my hood/rear deck and found the process to be rather difficult...dealing with the curves/humps on the car and keeping the air bubbles out of it. I wouldn't want to attempt doing the whole car without a lot of help from experienced folks.
If you want it done right, you'd best just take it to a business that does this all the time. It will be costly [not as much as a paint job] and it won't last more than a few years, unless you keep it coated with a UV filtering coating like Nu-Vinyl or Meguiar's protectant for plastics. Zaino (a polymer polish) might also block UV and still keep the surface shiny.
I think you would get the best prices in a large metropolitan area where there is a bigger market for this stuff. Keep us "in the loop" if you do more research or actually have it done.
Old 02-04-2013, 12:11 PM
diehrd
diehrd's Avatar
The new wrap is very easy to work with air bubbles are easy to eliminate with the newer 3M wrap.. It is designed specifically to deal with air bubbles.. I just think that rear quarter area and back deck would be a problem because you would need a sheet way bigger then is sold on line.
Old 02-04-2013, 12:17 PM
7T1vette
7T1vette's Avatar
Also be aware than any little surface defect...bump, nick, pit, bubble...will show up just as badly when covered with a vinyl surface. It will NOT hide defects, unless you prepare them properly [filling, sanding, etc.] before installing it.
Old 02-04-2013, 12:50 PM
briankeery
briankeery's Avatar
Look into Plasti-Dipping the car. Should get you by until you're ready to paint, and it'll probably be a lot cheaper than wrap.
Old 02-04-2013, 02:19 PM
CaptPaul
CaptPaul's Avatar
How hard is it to remove Plastic Dip when you are ready for paint??? Thanks, PW
Old 02-04-2013, 03:16 PM
TheSkunkWorks
I'd suspect "they" make wrapping a curvy body look a lot easier than it actually is...
Old 02-04-2013, 04:38 PM
briankeery
briankeery's Avatar
Well, according to this vid, it's looks fairly straightforward.
Old 02-04-2013, 05:07 PM
Jerry82
Jerry82's Avatar
I have worked with vinyl graphics and a wrap is not as easy as it looks, but if you pay to have it done is no big deal for installers. i would not recommend tackling it yourself because you may be out the $$$ invested on the vinyl. my $.02
Old 02-04-2013, 06:10 PM
Redwing01
Redwing01's Avatar
2015 C3 of Year Finalist
I know I wouldn't attempt it but it does look pretty cool!
Old 03-30-2013, 11:25 PM
donnie1956
donnie1956's Avatar
https://www.dipyourcar.com/home.php. Looks pretty easy and a color change in an afternoon. Something to consider if you don't have the $5-8K for a full on strip and paint.
Old 03-31-2013, 12:00 AM
holden7896
holden7896's Avatar
I did 2 stripes on the fender like the new grand sports and that was challenging. Took about 2 hours and it wasn't flawless. I would not even think about attempting the whole car.
Old 03-31-2013, 12:10 AM
harris1507
harris1507's Avatar
LOL, If you get the bunch of match box cars of your year and try the different colors to see what looks best.
Sorry in advance if this offends anyone!
Old 03-31-2013, 12:49 AM
AdamMeh
AdamMeh's Avatar
Can do some amazing stuff with wraps, but they do "wear out" quicker than paint.
I know this isn't a Corvette, but I found the color to be pretty amazing. Got me thinking that our '77 would be a good promotional car for my business. Not talking about putting words all over it, just a color that works. The color you see below is seriously being considered.
Old 03-31-2013, 02:33 AM
79CalShark
79CalShark's Avatar
I used vinyl wrap in another car and, depending on your objective, it may be a viable alternative but keep in mind that over time (time, weather and exposure), the vinyl will lift where folded, even if it is professionally applied. In my case, I used it as an accent on the hood and trunk and eventually replaced the vinyl with paint. Turned out to be an expensive exercise.
To vinyl wrap
Quick Reply: vinyl wrap
