Just how good is POR 15??
Navigator
Is this pan too far gone? I'm no welder, and this was to be a father son project, now it's just me, so $$ is tight.... I have the rest of the interior ready to go, but often the first step is the hardest!!
Side note: this place is a life saver when you've lost the only inspiration to a project vette... THANK YOU ALL!
glassing
I've glassed much worse, if it's not structural shouldn't be a problem. use multiple pieces / sheets of sea mat. back it on exterior with duct or masking to keep resin in. no need for a kit just get to home depot. wire brush it and use converter to clean up surface rust. Henry's roofing patch on exterior side, cut with some turpentine. that rot at the toe board could be reinforced with a 1" strap of aluminum stock riveted from kick panel to tunnel.
i'm sure you'll be good with a cheapo fix just watch out for the exhaust heat under the fix. the jag in my garage pics had VERY bad pans. sea matted them and you could stand on 'em all day
