body c3
Well, first welcome, secondly.......try posting your request in the tech/performance section of the forum. I'm sure you will get a detailed answer there, good luck.
taking the body will lead to......the very expense, while I am at it ~ Disease.
There is no cure.
There is no cure.
Received 1,468 Likes
Cruise-In II Veteran
Do you need to? My advice is not to do it if you do not have to. There is a very common misconception that all C3 bodies must always be removed from the frame in order to be restored. Not true. You can complete a reasonably thorough restoration with the body on the frame. The assembly instruction manual (AIM) helps since it shows the body mounts. Do the Google thing. There are three or four Corvette restoration books which discuss removing the body.
Don't we know it!
But seriously, it's a bunch of work. It will eat up more time and money than you budgeted. I had to do mine a few years back, just to replace three rusted away body mounts. By the time I had it back together, six weeks later, the engine was rebuilt ($$$$) and the unplanned "incidentals" were another $1500 on top of that.
