Won't start (smoke effects too!)
Old 02-23-2013, 10:52 PM
pj_corvette
pj_corvette's Avatar
Default Won't start (smoke effects too!)
Hi
My '78 wont start and I was wondering if someone could point me in the right direction.
I was trying to start it after about 3 months of inactivity. At first, the engine turned but never got going. Then, the engine would not turn. You could hear the starter trying to get it going, but not enough to get it to turn.
Eventually, smoke started coming out from the starter area. I thought I had fried the starter, but checked the wiring and it was all burnt up, so I thought it was the wiring that fried instead.
So, I ordered a new starter wiring harness and replaced the old one, thinking it would fix it. Still, won't turn. The starter does engage the engine, but can't turn it.
So now, I'm confused. I mean, can the starter be bad anyway even if it does engage the engine and tries to turn it? If the smoke had come from the starter, would it still try to engage and turn the engine? Is there anything else I should be looking at besides the starter
By the way, all of the above tests happened with jumper cables coupled from my other car to the vette's alternator, because the vette's battery is dead now.
Also, the engine is not seized. I was able to turn it easily by hand.
Thanks.
PJ
Old 02-23-2013, 11:19 PM
Mike Ward
Mike Ward's Avatar
Charge the battery then connect the booster cables directly to the battery. The alternator wire is far too thin to carry that much current.
Old 02-24-2013, 12:29 AM
Ibanez540r
Support Corvetteforum!
Ibanez540r's Avatar
Starters probably not getting enough juice.
Also be aware of the shimming of the starter. If it does it with plenty of juice, it might be binding and could need shimmed.
Old 02-24-2013, 12:31 AM
Ibanez540r
Ibanez540r's Avatar
...also never crank a starter for longer then 5-10 seconds at a time, and then break. They heat up quick.
Old 02-24-2013, 09:17 AM
BOSTONCAMARO
BOSTONCAMARO's Avatar
have spark?
Old 02-24-2013, 09:18 AM
BOSTONCAMARO
get good starter and wires in..then make sure there is spark and fuel
Old 02-24-2013, 10:33 AM
SuperBuickGuy
SuperBuickGuy's Avatar
Yes, bushes are most common issue (one breaks off, or it's simply worn), bearings could be rusted.... the list goes on.
Old 02-24-2013, 12:56 PM
toolman0114
toolman0114's Avatar
You can buy a smaller size, high torque starter from any parts place, part source, NAPA, etc, that come stock on some Chevy pick up trucks. I don't remember what years, or part numbers, but it bolts right up. Just tell the counter guy what you are doing and he should know exactly what one you need.
Old 02-24-2013, 01:43 PM
Raphiki
Raphiki's Avatar
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
If you take the starter to the NAPA store they will run a draw test on it to see how much the starter is pulling. If it's pulling too much juice get a new high torque one.
To Won't start (smoke effects too!)
Quick Reply: Won't start (smoke effects too!)
