1971 Journey
#542
Getting close.....
Tomorrow I should get the cooling system finished, charcoal canister in then connect battery and be almost ready to fire it up. :-)
#548
Ran up the oil pump with the battery drill
Till I had oil up through every push rod.
Then started it up.
Had way too little advance so it took a couple of goes.
Then started it up.
#550
Glued weatherstrip back on hood and temporarily refitted hood and latches etc.
Will pull latches again and paint them etc before final assembly.
Want to have it drive-able for next Sunday at Wakefield Park so can drive down and watch the Corvette track day.
#551
Wanted quicker way to replace belts and tension them properly.
Alternator is not an issue but power steering is hard to pull out as you cant pull the can part.
So I cut a couple of aluminum tube sections and bolted them to the front of the pump.
Now adjusting is a quick job without fear of damage as you have a leverage point.
#552
Jack has been given first coat of black enamel.
Pain to do as there are so many overlapping parts. Need to coat it then juck it up and do again etc.
#553
Got all the vacuum systems operating again, lights wipers etc so roadworthy now.
If the weather is good will be taking it down to Goulburn to watch the LeadFoot Challenge this Sunday.
Looks like about 20 vettes from Canberra, NSW and Victoria will battle it out.
#555
We went to Wakefield Park Raceway in Goulburn today,
Was a track day for the HSV club and Corvette clubs.
Lots of interesting Vettes and cars in general.
Was not an entrant but they let us do a few laps that was great.
#556
The radiator in my vette does not have an overflow catch can and has a tube that drops to the ground as per design.
This requires you to leave a few inches at the top of the radiator for expansion.
Decided to play around with either filling it to full and putting a recovery can on it or at least a catch can to stop the coolant drips getting all over things.
Started with a drink bottle to see how much comes out and pick a usable location.
Found on ebay a cheap ($30 from HongKong) aluminum can.
When it turned up it was chromed which I did not like, but luckily it was also cheap chrome and I got it all off in 5 minutes.
All cleaned up and now I just need to make some brackets and then test filling it all the way.
#557
A couple of deliveries this morning.
Some parts from Zip for a few more projects and some stereo gear.
Amp the same as Glen (StLeon) to go under the seat 50w x 4
Electronic Crossover to a split the 1 set of RCA's I have from the deck with 2 high pass and 1 low pass filter to allow for the front speaker sets and possible subwoofer. (Got to plan ahead)
#558
Parcel from Willcox arrived today.
Have been testing the replacement stereo with a CD interface I picked up to connect the iPod
The interface makes the iPod emulate the 6 stack CD.
Works ok and music quality is good but lacking in ipod control.
Was worth a play.
Was worth a play.
#560
September 2012
Saw that Willcox had an extra discount so decided to get some new door panels but first I wanted to check if I could refurbish the existing ones as they had a few cracks.
So I pulled the drivers panels off and found it was a reproduction anyway so I decided to just order 2 new ones.
While I was there I had a look why the glass did not go up fully and one thing led to another and I ended up stripping the door of all hardware, glass etc.
Cleaned up the mechanisms
Too much flex in existing regulators so will order two new ones.
Only took 40 minutes to strip it all out, lets see how long it takes to put it back :-)
