1971 Journey
#421
I had not discussed it on this forum but the upper yoke of my column is in 180 degrees out. Must have been repaired at some stage and put in upside down.
Plays havoc with indicator cancel etc etc.
So to resolve it
- the Rag Joint needed splitting and rotating of the column side 180 degrees (When centered flat edge is bottom).
- the upper part of the column needed removal and rotation 180 degrees so the chisel mark in the upper column points down but the upper case is in correct location.
Now blinkers cancel fine etc. Much simpler than pulling column apart to correct yoke.
So to resolve it
#422
Fan control is now finished and installed.
Ralph did a great job.
The control panel in the ash tray.
The control box.
Test rig.
Wiring instructions laser etched on bottom of case.
Easy to use.
Press fan 1 or 2 button to manual control fans.
Set threshold for each fan by holding down button at desired temperature.
You can also control led brightness (it adapts for night day) and fan cut off points.
main led is blue as car warms up, green when at desired running temp, yellow when one fan on, red when 2 fans on, flashing when 10 degrees over 2 fan point and beep as well beyond that.
The control box.
Test rig.
Easy to use.
#423
Note to self, dont get too smart !!!!
Was putting the column back together and i was about to mount the ignition switch.
Thought it looked a bit crappy (even though it worked perfectly) so I decided to take it all apart and chemically treat it etc etc.
Bad idea, 12 small springs and bits and pieces later are all over the floor.
Got it all back together but i think I lost something as I have no accessory setting.
No problem will do for the moment and i will order another one to replace it later.
#424
Originally Posted by sirfixalot
Are you sure its not just a matter of adjusting switch position on column have been caught before
I still think there is something missing in it :-)
But its too loose now, lost the distinct notches between settings.
Never mind its working ok till i get another one.
Pontiworld has one so will call tomorrow.
#425
Got the vette flat bedded to the exhaust shop Monday.
Gave me a chance to clean the garage :-)
Got a 2.5" mandrel bent system made up. I did not want it to be too loud but have a nice sound. Seems to have hit the mark.
Tune was WAY off though and it ran like a PIG, by the time I got home it had fouled the plugs.
Turns out the springs I used in the advance were so weak they came all on at just over idle and a vacuum leak from a cap they popped off so the settings were off the mark.
Fixed those things up now and it runs nice.
Adjusted the semi coilovers a bit more to get it as level as possible.
#426
So the good and the bad.
The steering with the Borgeson box is fantastic, brings the car into current century.
Precise, smooth and feels like a different car - still dont have an alignment yet so can only get better.
The bad is the intake manifold is leaking oil from the rear GRRRRRRRR.
Will have to take it off and do it again. :evil: :evil: :evil: :evil: :evil: :evil:
#428
New ignition switch arrived from Ponti World
They got it out to me next day - great service.
Should get it mounted back in vette tonight.
#429
Column went back in with new seals and tightened into the rag joint.
Took it for another spin out on the highway and all I can say is wow - it drives like a different car.
The steering is so precise, certainly one of the best changes I have done.
#431
Underside of the hood had some bubbles in the paint so I started to give it a light sand.......
After these shots were taken it was all back to glass.
Not sure if i should give it a paint with fiberglass resin or some sort of gel coat primer before painting or not .... any ideas. ?
#432
Need to take the vette for an alignment this week, either Monday morning or Thursday Friday as i am traveling for work in between.
Needed to get the hood fitted so I am less an issue for the Police.
Brackets back on.
Hood fitted and lots of adjustments to get it almost correct.
The hood latches have not been restored yet but they need to go back in.
Brackets back on.
#433
I had spend hours stripping the underside of the hood and repainted it yesterday.
Was not happy at all so stripped it back to glass again - what a pain.
Have decided to use one of the under hood liners instead so ordered it yesterday.
#435
Did some final height adjustments.
Front is 60cm from bottom of rim lip to wheel arch lip
Rear is 61cm from bottom of rim lip to wheel arch lip.
#436
I went and got some rubber from Clark Rubber to fill the top area of the radiator to the support.
Then marked it for the hood seal and spread weatherstrip adhesive.
#437
My front grills had seen better days, the chrome is starting to break up etc.
So I stripped and cleaned them up as good as i could then gave them a few coats of Satin black paint.
I wrapped the old lens covers in glad wrap as a masking method.
I know they should have been silvery grey but black looks good and it hides the problems much better than the grey.
May have to look to get them stripped and re chromed at some stage.
#438
After some work with the razor blade they don't look too bad.
By using the satin black the areas where chrome has deteriorated don't stand out as much.
I think the grey would have offered less contrast so the issues would have been more obvious.
Very happy with them.
Re Chroming possibly in the future.
#439
I built new brackets to mount the grills to the bumper tabs that gave more adjustment.
Final fit, first the headlight shields.
Then the grills and plenty of adjusting then some more :-)
