1971 Journey
#221
Have not been able to get much time but I have the lower control arm out now.
The upper arm needs the power steering pump moved or removed to get enough room to get it off.
Radiator out as well.
Some of the parts removed.
#222
There is 2 cracks in the passenger side inner fender so I will grind them both out and lay up some glass on the wheel well side.
I have also thought the lower front apron sat higher on one side than the other.
So its a good opportunity to strip all the grill parts below the bumper and do some serious measurements.
I know the bumper measurements to ground on each front corner are the same while it is up on the stands.
Have worked out that I should be able to slice the apron off some of the other support panels if needed to change its height on one side.
It all seems simple when you plan it but lets see how it goes :-)
#223
Went down the coast on the weekend and got back today. But had a little bit of time to get started.
First the power steering needed its fluid removed.
Drained the fluids into a pan.
Removed the mount for the ram then compressed it to pump its fluid out.
Could not easily pop the other end of the ram out so decided to remove all the linkages as one.
Needed to pop the passengers side tie rod.
All out except control valve.
Next I popped all the other joints.
#226
I got my new (Restored) correct serial number carb last week and unpacked it for a look today.
Very happy with how it looks.
Lets hope it runs as well as it looks. The re builder came recommended and his customer testimonials were great.
#227
Originally Posted by YLLA 88
Hey Craig, Who's the Carby Guy? :o
Philip Cancilla
http://www.customrebuiltcarbs.com
Custom Rebuilt Carburetors LLC.
200A Wood Avenue
Middlesex, NJ 08846
He found a carb with corrects serial number and date code then rebuilt it for me. Took a few weeks once he started the rebuild.
So the carb was original built March 12 1971 and went onto my May 71 vette. That seems to work well in NCRS terms.
#231
Next i wanted to remove the front brake lines, proportioning valve etc.
Started with a loopback on the master cylinder.
Lines came out easily however.......
Where they joined the proportioning valve they were not coming off.
Heat, penetrating oil etc no way it was moving....
For most it did not matter as I could just junk them but I was not going to replace the front to rear line so I needed it off.
In the end I cut into the valve and got it off.
A little bit of damage to one section of the thread but the flare joint is fine and it tightens up ok on the new valve so should be fine.
#236
Steering box about to be removed.
And out with rag joint removed.
I will pull the column a bit later as it needs to be shortened a little to fit the new Borgeson box.
Gives me a chance to clean it up, replace the lower bearing if needed and paint the interior parts.
#237
Removed the exhaust manifolds and cut the exhaust out to the cross member.
My son Matt has been helping out and it is much quicker with 2 people to strip some of this down.
