New C3 owner, wondering about L84
Old 02-15-2013, 04:37 PM
dcoffee
3rd Gear
dcoffee's Avatar
Default New C3 owner, wondering about L84
Hello,
I am new here, and I am in the process of buying my very first 1979 C3. I've been talking to the owner about it, and I have pictures, and I believe it to be a L84.
I know the engine needs work, and I intend to do it, but I was wondering if by looking at it you can tell that it is indeed a L84. I can upload more pictures of the car if needed to make that determination.
Owning a stingray has been a dream of mine since I was a kind. And tomorrow, I will hopefully own one.
Old 02-15-2013, 05:06 PM
BKarol
BKarol's Avatar
In 79, they had a L48 and a L82. You have the numbers mixed up.
No way to tell if that is a block from either without you looking at the stamp pad and looking up the suffix. Could be a truck or van motor.
It is located near the front of the passenger side valve cover. It will look like this (the suffix ie.CMR will tell you what block it is. Use a wet cloth not sandpaper to clean it if not visible):
Post what you find here. Someone will decode it for you. And just because the vin or title says one thing it does not mean the block was not changed. Good luck.
Old 02-15-2013, 05:09 PM
dcoffee
3rd Gear
dcoffee's Avatar
thanks for the info. If it is a CMR suffix, does that mean it's an L82?
Old 02-15-2013, 05:10 PM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Most likely a base L48 if its the original, I think the L82 came with aluminum valve covers. If i'm not mistaken an L82 would also have a change in the the Vin# 5th dig 8=L48 4=L82
http://corvetteactioncenter.com/spec...l#.UR6zZGcY3zo
Old 02-15-2013, 05:12 PM
dcoffee
3rd Gear
dcoffee's Avatar
I actually think the suffix for that year, and for an L82 is ZBB. If anyone knows for sure, let me know.
Source: http://www.corvettecenterusa.com/Cor...ne%20Codes.pdf
Old 02-15-2013, 05:19 PM
BKarol
BKarol's Avatar
CMR is my 78 engine. It represents L82 4spd. 0420 means the engine was built on April 20.
In 79, they had zba & zbb for the L82.
There are 7 other codes for the L48.
Old 02-15-2013, 06:04 PM
John 65
John 65's Avatar
Yup, CMR is the 220HP (L82) motor from a 78, 4 speed car. The 79's had 5 more HP.
Old 02-16-2013, 12:28 AM
WHITE 1974
WHITE 1974's Avatar
Looks like an L48 judgeing by the plain corporate blue valve covers but the block number will tell all
Old 02-16-2013, 10:11 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
The engine in your pic look like an L-48. Check the engine identification code for confirmation.
To New C3 owner, wondering about L84
Quick Reply: New C3 owner, wondering about L84
