Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2013, 12:55 PM   #1
1974ta
CF Senior Member
Default Bead Blast in MD
Hi Guys,
I am located in Damascus, MD
Would anyone allow me to pay for use of their bead blast equipment to clean up a bunch of hardware before I phosphate the same hardware.
I would be happy to contribute towards the purchase the blasting media or even provide the labor to bead blast any parts you may want done too.
Thanks,
Bill 301-440-0838
1974ta is offline   Reply With Quote
Old 02-09-2013, 04:36 PM   #2
RodgerF
CF Member
RodgerF's Avatar
What kind of hardware do you have? Maybe something like this would work. http://www.eastwood.com/18-lb-vibrat...and-media.html
I have a small siphon feed sand blaster that would work if you have an air compressor.
Rodger
RodgerF is offline   Reply With Quote
Old 02-09-2013, 05:07 PM   #3
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Bill,
How many, and what parts, do you have.
Might you consider cleaning them with a wire wheel mounted to a variable speed bench grinder?
I used this method for all my parts because I was concerned that blasting might change the texture of the surface of the parts and bolts.
Regards,
Alan
Alan 71 is offline   Reply With Quote
Old 02-09-2013, 05:21 PM   #4
1974ta
CF Senior Member
Default Hardware
Quote:
Originally Posted by Alan 71 View Post
Hi Bill,
Regards,
Alan
Hi Alan,
I am seriously thinking of this option for the same reason.
How did the phosphate treatment work for you after just using a wire wheel. I know that you did a fabulous job on your 71.
I was thinking about using evapo-rust then wire wheel.
The hardware is in very nice shape as it spent most of its time in the desert of texas.
Thanks,
Bill
Old 02-09-2013, 05:44 PM   #5
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Bill,
Both the phosphating and black oxide worked very well after using the wire wheel.
I found that the part needs to be very clean and then you shouldn't touch it without using tongs or latex gloved hands.
Here's a picture of both a phosphate and black oxide bolt.
Regards,
Alan
Click the image to open in full size.
Old 02-09-2013, 06:14 PM   #6
1974ta
CF Senior Member
I am sold Alan
Did you use a bench mounted grinder with wire wheel?
BTW: What is the head mark on your alternator ground bolt?
Thanks,
Bill
Old 02-09-2013, 06:49 PM   #7
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
Looks like blued on top, and parked, er, phosphate, on the bottom...
I need a bigger house... with a grinder and room for a bunch of recoating buckets!
Shark Racer is offline   Reply With Quote
Old 02-09-2013, 06:59 PM   #8
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Bill,
Yes, I have a Sears variable speed bench grinder that I bought back when I started all this. It's held up well.
I use wire wheels of varying coarseness.
I have the zinc and manganese phosphate materials from Palmetto Enterprises, and the black oxide kit from Caswell.
The phosphate is easy to do although the bath does need to be heated.(Stainless steel pan, hot plate, and thermometer). I then immerse the part in an oil based sealer.
The black oxide process is just immerse the part in the liquid, and then the sealer.
The shine on the black oxide bolt in the picture is from the oil bath. It soaks in and pretty much disappears in a day or two.
I still haven't gotten my zinc plating going yet, but hope to in about 6 weeks.
Regards,
Alan
Old 02-09-2013, 07:22 PM   #9
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Bill,
The alt. ground bolt is an 'R' with 3 slashes..... it's the original.
Regards,
Alan
Old 02-09-2013, 07:48 PM   #10
1974ta
CF Senior Member
Default Bolt
Thank you Alan.
I am trying to see if there are any head marks besides the R. So far 100% of the original have been the R.
I am looking for the correct bolt and have a couple leads.
Bill
Old 02-09-2013, 08:36 PM   #11
mrvette
CF Senior Member
mrvette's Avatar
Did you try Tony's Corvette shop in G'burg?? he was my old club guru some years ago.....
did fine by me back when.....
mrvette is offline   Reply With Quote
Old 02-09-2013, 08:43 PM   #12
1974ta
CF Senior Member
Default Tony
Tony has been a huge help. He has done a number of jobs for me that require specialized tools.
This is something I want to do so I can do it in small batches as I work through the chassis.
Bill
Old 02-10-2013, 06:35 AM   #13
Ibanez540r
CF Senior Member
How many and what size parts are you talking about?
I'm in Ohio, but if it's just a few misc. bolts, brackets, etc. you could toss them in a flat rate box and send them to me. I'll blast them for you.
Ibanez540r is offline   Reply With Quote
Old 02-10-2013, 08:25 AM   #14
1974ta
CF Senior Member
Default Bead Blast
It is quite a few pieces of hardware. Basically all the hardware from disassembly of everything behind the engine including trans, rear, T arms, gas tank, bumpers, etc..
I am going to take Alan's advice and go out and purchase a bench grinder and wire wheel attachments. Most of what I have will be treated with zinc phosphate. I have Tony's corvette doing the few items that are zinc plated. He sent them out with a large batch he was having done on one of his own cars.
Thank you for the offer. I will definitely keep it in mind as I continue.
Bill
Reload this Page Bead Blast in MD
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
