wiper motor plugs
wiper motor plugs
Can anyone tell me which way the plugs go on the wiper motor itself and the switch inside the car. The plugs can go either way.
Received 2,878 Likes
Hi Skip,
I'll try the connection at the switch in the dash.
The connector has a little tab on one side.... the tab needs to be toward the right as the connector goes into the switch.
Look at AIM UPC 12 Sheet B5. It's shown there.
Regards,
Alan
Regards,
Alan
Thanks guys I am heading out there now I think the switch plug is backwards. The wipers were the reason I installed a new harness in the first place.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Does that bench test work for testing my 73's wiper motor, i belive it was working when i took it off 3 years ago but i want to test it before reinstalling, can i use a battery for my power source and what would be a good way to ground, is there a way to test washer pump as well? According to judging manual i have the correct and probably original motor, cleaned up ok, would like to make it look a little better, were they supposed to be painted?
Former Vendor
Here is the link to the video for bench testing your motor http://willcoxcorvette.com/advanced_...=wiper%20motor
Or if my voice and vids are boring.. this page will show you how to bench test.
http://willcoxcorvette.com/product_i...ducts_id=27341
