Need help quick! Antifreeze frozen!
Mike,
There is something very strange here. A quality 50/50 mix should show close to -40*F. I have seen -45*F and DexCool in my Impala becomes a slush puppy but it does melt down pretty quickly. His reading of -15*F is very unusual. That is not good enough in these temps.
Did you hear on the news that we were 'the coldest capital on Earth' today? Wind chill (or 'windshield' as my old neighbour used to say) factor tomorrow AM will be -41. Time to put my long pants and a shirt on.
Back in the day, I had a buddy that would put the end of a plugged-in soldering iron in his radiator at night to keep it from freezing. He claimed it worked.
But he mixed it what ever was already in his rad. No telling what that was.
I can take this opportunity to start an oil thread. Yes, Mobil 1 5W-30 in my Impala does flow at these temps. The pour point is -42*C. Getting pretty close, however!
All kidding aside, I am glad my 1974 is in a climate controlled 60*F commercial facility until April. No worries there.
Terrorizing Orange Cones
Good to read that the OP seems to have his antifreeze protection back into spec.
To all of our friends in the Great White North... stay warm. Those outside ambient temps may be good for some but I'm glad to be closer to the equator. Brrr...
well the tester i'm using is peak antifreeze tester that i bought new today.i'll check it again, but the arrow was between 15 to 20 below. the new antifreeze is much more green than what was in there before. it was around july that i put most of a gallon of 50/50 in. maybe all the was in there was water. and it ended up watering down the 50/50 mix even more. thanks for again the help, in over 35 years since my first car, i've never had this happen! so with a gallon of straight new prestone, i should be around 45 below reading?
ji58,
How did things turn out for you last night? I hope well. We here saw -38*F windchill. A little milder tonight: ~-32*F windchill. A little hard on the nerves; even windshield washer fluid can turn to slush.
These temps are a good argument for Mobil 1 synthetic 5W-30 (I have in my DD 2007 Impala) or even 0W-30. I changed out the 5+-year-old battery for a very strong AC Delco PG34 in early December. Good choice. No starting problems.
I am not advocating Mobil 1 for older Corvettes! (I say that before Mike W. jumps all over me ). It was just a comment on the weather.
The lowest I recorded overnight was -28 so my -35 windshield washer fluid was Ok good decent margin.
'Windchill factor' doesn't lower the temperature of things below the actual temperature, it's just a 'feels like' number for humans.
A real treat is to throw up a cup of boiling water into the air and see what happens.
But it was d*** cold when I did the groceries today with the wind.
Was up in Zama Lake in -48 and got hit with the prop wash when our Dash 8 was heading off the ramp, talk about wind chill, holy crap that was cold.
On the Topic of Antifreeze I always drain the block as well when i'm doing a change and usually mix it for -45c
That's just an average winter day in Alberta
With the Corvette, it is probably -35*F or so protection. But it is sitting in heated 55*F commercial storage. I don't worry.
Would still like to hear from the OP.
ji58,
