Corvette rear deck vent grilles
Ok I have a 1977 Vette, Numbers match, something odd here the rear deck looks like there were grills there. After looking under the deck there is the actual indentation where the vent would be and drain. I cannot find a 1977 vette. with Rear Vent Grills, also looks like there was a luggage rack once upon a time. I looked for tell tale signs of body work no where can i see splicing of any sort. Does anyone know if a 77 had grills on deck?????
Frank
Frank
Received 2,878 Likes
Hi Frank,
I believe the 76 model year was the last year for the vents on the rear deck.
Did a/c become standard in the 77 model year? A/C cars didn't have the ventilation vents from 68 on.
Regards,
Alan
Regards,
Alan
Received 1,470 Likes
Cruise-In II Veteran
77s had no rear deck vents; you should see no signs of them ever having been present.
For 77, luggage racks were an option; the mounting holes were drilled at St. Louis and the rack shipped with the car. There was no splicing.
Go here: http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your car. If the car had the luggage rack option, it will appear on the invoice.
RearDeck
:crazy: Ok then the rear had to be replaced once upon a time. Looking under the lid is the actual molded cutout never been cut. I did pull out the hard epoxy from the top and discovered the indentation, When I start striping it down i should see if any work was done. If a rear splice was made where would be the most logical splice be made?. I am baffled, Any other tell tale signs I could look for like T-Top Post ? I will probably install the grills anyway just for the looks!
The other likely place to seem a rear end repair, would be along the factory bonding strip seems. These are located an inch or two down from the fender peaks, running the length of the fender, from the door jam to the rear bumper.
Follow up????
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,351 Likes
