needing help
Old 12-18-2012, 06:18 PM
Ron L
Ron L's Avatar
Default needing help
I'm looking on buying some 68 doors, I have power window ,the ones I'm looking at have stander. Can they be converting to power windows?
Thanks Ron
Old 12-18-2012, 06:20 PM
TimAT
TimAT's Avatar
Unless they (GM) did something weird in 68, (ok, more weird than normal), the power motor mounts on the lower end of the regulator and has a couple of bolts that secure it to the inner panel. Check your AIM. It should show the differences if any.
Old 12-18-2012, 08:44 PM
Ron L
Ron L's Avatar
Thanks for the help
Old 12-18-2012, 08:45 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hi Ron-
The doors will work fine. Just make sure to cut the hole in the front of them for the conduit before you install them on the car. It's almost impossible to do this afterwards.
Willcox
Old 12-18-2012, 08:51 PM
Ron L
Ron L's Avatar
Hi Willcox,
Thank you so much , I been looking for door for some time now is been so hard finding parts for a 68 .
Again Thanks Ron
Old 12-18-2012, 09:27 PM
AGVI
AGVI's Avatar
Canadian Events Coordinator
Originally Posted by Ron L
Hi Willcox,
Again Thanks Ron
Try asking for what you need here.
http://forums.corvetteforum.com/c3-p...ale-wanted-57/
Old 12-19-2012, 08:16 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
...been so hard finding parts for a 68...
Welcome to the 68 owner's club.
To needing help
Quick Reply: needing help
