routing of wiring for spare tire
Old 12-18-2012, 09:35 PM
beautimus
beautimus's Avatar
Default routing of wiring for spare tire
can someone describe the routing of the wires for the spare tire light. pictures are a plus if you have them. i seem to recall a post on this a couple of weeks back but i cant find it. i have the car back on the frame again and i am trying to sort everything out. i have found a couple of wires coming out of the passenger compartment above the rear axle. and it had a black box (about the size of a match box)
butt-spiced into them. This being the first corvette that i have ever worked on , can someone tell me how this wiring should be, and if the black box should be there or not. thanks for any insight. Tony
Old 12-19-2012, 08:12 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
What model year? If the car had a spare tire light, the assembly instruction manual (AIM) will show it. The wiring is likely part of the rear harness.
Take a pic of your black box. Offhand, I can't think what it might be.
Old 12-19-2012, 05:09 PM
beautimus
beautimus's Avatar
the car is a 1974 t-top car l48 auto. the wires are a pair of 14 ga. brown wires that almost look like a lamp cord type wire where the 2 are siamessed together. and here is the picture of the black box. oh and the 2 green wires on the box wire spliced to the 2 brown wires, while the yellow on the box was not connected.
Old 12-19-2012, 05:13 PM
Easy Mike
Easy Mike's Avatar
If memory serves, 74s did not have a spare tire light; that or I never had an occasion to use it on my 74.
Black box looks aftermarket to me.
To routing of wiring for spare tire
Quick Reply: routing of wiring for spare tire
