Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-22-2012, 10:26 PM   #1
news2me
Junior Member
Default The Word Original
I have a 77' thats completely stock with Numbers Matching Engine and Drive Train. The Interior is all Original. It only has 38,000 miles on it. Looking at the car it looks the way it left the factory. Yes, the brakes. belts, hoses, radiator and the other BS has been done over the last 35. The only things that has been changed on the car is an After Market Radio, The BF Goodrich Tires and a Repainted the Original Code 80 color about 12 years ago..... The question I have is I want to get a Show Board. And will it be fair to use the word "ORIGINAL" on the Show board, since I don't have the factory radio, tires and it's a repaint. But it is painted to code and tires needed to be replaced.... CAN I CALL IT "ORIGINAL"
news2me is offline   Reply With Quote
Old 11-22-2012, 11:28 PM   #2
exposingtime
CF Senior Member
exposingtime's Avatar
Gary Haftel
Send a message via AIM to exposingtime
Call it NCRS gold certified.
Just call it unrestored. Repaint is not a restoration to me. All of the others qualify as maintenance to me.
exposingtime is offline   Reply With Quote
Old 11-22-2012, 11:47 PM   #3
ptroxx
CF Senior Member
ptroxx's Avatar
Location: Rohnert Park/Sonoma Co. ca/born in NY Rockaway Beach
PICS...lets see pics of the car.in and out ..
ptroxx is offline   Reply With Quote
Old 11-23-2012, 12:43 AM   #4
Mike Ward
CF Senior Member
Mike Ward's Avatar
Location: about an hour away from Paul74 in Ontariariario
Since you already said 'numbers matching' which is pretty ambiguous, may as well use 'all original' too.
Mike Ward is offline   Reply With Quote
Old 11-23-2012, 02:41 AM   #5
scottyp99
CF Senior Member
scottyp99's Avatar
Here's what the dictionary has to say about the word "original". Let your conscience be your guide. I think you know the answer to your question, but you're looking for someone to tell you it's OK.
Keep the shiny side up!
Scott
scottyp99 is offline   Reply With Quote
Old 11-23-2012, 07:40 AM   #6
Alan 71
CF Senior Member
Alan 71's Avatar
Hi,
Just curious.... how can repainting a car NOT be restoration?
Regards,
Alan
Alan 71 is offline   Reply With Quote
Old 11-23-2012, 07:53 AM   #7
stingr4y
CF Senior Member
stingr4y's Avatar
Perhaps specify "original paint color", if you are concerned about it. I agree that the repaint could certainly be a restoration.
The radio and tires should be obvious though.
I tried making a sign for mine and gave up when I realized everything I put on there might be questioned somehow.
good luck
stingr4y is offline   Reply With Quote
Old 11-23-2012, 09:19 AM   #8
Tim H
CF Senior Member
Tim H's Avatar
I would rather have a car that someone kept up on maintenance than a pretty non original paint job.
Paint is a part number on the cowl tag so its part of the car and if the body has been repainted then its no longer original.
You might as well up grade the engine into the 21st century with some new belts and hose and add some mags and headers, it won't be worth any less.
__________________
1976 Stingray, 350, 4 speed, 750 Holley, Comp Cams 474 lift, 276/284, Professional Products polished "crosswind" intake, Summit headers, Flowmasters!
Tim H is offline   Reply With Quote
Old 11-23-2012, 09:33 AM   #9
War Bonnet
CF Senior Member
War Bonnet's Avatar
Location: "I fear the day that technology will surpass our human interaction. The world will have a generation of idiots." Albert Einstein
Exterior= repainted
Interior= replaced radio
Mechanical= belts, hoses, plugs, wires, filters, radiator, replaced
Chassis=Tires replaced, brakes, not much else mentioned? Shocks?
In all fairness to the all original car, what would be your answer?
WB
War Bonnet is offline   Reply With Quote
Old 11-23-2012, 09:38 AM   #10
Mike Ward
CF Senior Member
Mike Ward's Avatar
Quote:
Originally Posted by Alan 71 View Post
Hi,
Regards,
Alan
Not like you to be opening a can of worms Alan........
It could be argued that the paint, although possibly identical to the original colour applied by the OEM, is not the same type, manufacturer, method of application, level of gloss, etc. etc. etc.
I find the present NCRS flight judging rules to be very forgiving in this area.
Old 11-23-2012, 10:25 AM   #11
gq82
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13
gq82's Avatar
On a show sign I would call it "Mostly Original".....a modern radio gives away the fact it's "All Original".
gq82 is offline   Reply With Quote
Old 11-23-2012, 10:29 AM   #12
Brooklinite
CF Senior Member
Brooklinite's Avatar
scott.junior.988 GEERAY
'Original' is misused so frequently that it is basically meaningless.
Brooklinite is offline   Reply With Quote
Old 11-23-2012, 10:32 AM   #13
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
You can call it anything you want to. It's your car. Why not say it's original except for the aftermarket stereo? Better yet, put the stock radio back in it and you won't lose any sleep over what term you use.
Easy Mike is offline   Reply With Quote
Old 11-23-2012, 11:07 AM   #14
540 vette
CF Senior Member
540 vette's Avatar
I think original and 77 vette don't mean much. If you think it makes it worth more I don't think so. When I was looking for a vette to modify I chose a 77 because it will be another 75 years before they are a collector car.
I don't mean to burst your bubble if you were trying to keep it all original to keep any value. I would make it how I want it to be and not worry.
540 vette is offline   Reply With Quote
Old 11-23-2012, 11:22 AM   #15
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
Originally Posted by 540 vette View Post
...I think original and 77 vette don't mean much...
It means a lot to people who have original 77s.
Old 11-23-2012, 11:24 AM   #16
irvan
CF Senior Member
i can't remember who said it years ago but they are only original once, and i think that's before repaint, etc.
irvan is offline   Reply With Quote
Old 11-23-2012, 11:31 AM   #17
7T1vette
CF Senior Member
7T1vette's Avatar
You can't call it "unrestored" if it's had another paint job. And, you can't call it a "survivor" since lots of parts have been changed due to age/wear and you have a different paint job.
Why don't you just say that it is in 'factory' configuration with the original interior and the same paint color.
P.S. I interpret the term "original" as meaning that a specific part/piece came with THAT car from the factory.
7T1vette is offline   Reply With Quote
Old 11-23-2012, 11:47 AM   #18
qwank
CF Senior Member
qwank's Avatar
Just call it "stock"
qwank is online now   Reply With Quote
Old 11-23-2012, 12:01 PM   #19
AdamMeh
CF Senior Member
AdamMeh's Avatar
Quote:
Seems more fitting given the changes / work that has been done. Would love to see pics of it!
Adam
AdamMeh is offline   Reply With Quote
Old 11-23-2012, 12:31 PM   #20
Vettebuyer5869
Moderator
Vettebuyer5869's Avatar
Quote:
I agree with this. Obviously a car thats been repainted is not "original" according the the English language we see mangled and misused every day. Replacing parts also is not original. This isn't a hard question.
Describe the car as "mostly original design," "stock configuration," etc. There's nothing stock about the radio. "Almost completely stock" seems like a pretty good description.
Clearly there's no rules and you can do whatever you want, but as Easy Mike pointed out, when you park next to someone who actually has an original car, you'll end up thinking about it.
Vettebuyer5869 is online now   Reply With Quote
Reload this Page The Word Original
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
