Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-01-2012, 10:40 PM   #1
The Punisher
CF Senior Member
The Punisher's Avatar
Default White face gauges
Anyone install white face gauges. Would like to see some pics.
The Punisher is offline   Reply With Quote
Old 11-02-2012, 05:49 AM   #2
scottw
CF Senior Member
scottw's Avatar
Do a search for aftermarket gauges or autometer gauges and you will find all sorts.
I'm putting in Phantom's right now so I don't have any "after" pics but here is a pic with all but one gauge in the center cluster.
Click the image to open in full size.
scottw is offline   Reply With Quote
Old 11-02-2012, 09:00 AM   #3
stopherjones
CF Senior Member
I kept original gauges but put the white face overlays on them. I like them, especially for 20 bucks...
stopherjones is offline   Reply With Quote
Old 11-02-2012, 11:05 AM   #4
MacVette86
CF Senior Member
MacVette86's Avatar
I also installed the white face overlays on my original guages. It's easy and looks great.
__________________
1977 Corvette Coupe
White with Black interior
MacVette86 is offline   Reply With Quote
Old 11-02-2012, 12:16 PM   #5
Learning_Curve
CF Senior Member
Learning_Curve's Avatar
I've been checking these out. Lot cheaper the Autometer, and what could be more appropriate for a C3 than "Shark Gauges"?
Learning_Curve is offline   Reply With Quote
Old 11-02-2012, 12:30 PM   #6
mrvette
CF Senior Member
mrvette's Avatar
No PIX, also no stereo/tunes.....and so I bent up a aluminum plate for the center gauges, that are white faced and the overlays done for the speedo/tach, my tach is from a 75-77 and so the white overlays don't line up on the bolt holes in the dial center, a little paint made it somewhat passable, the old '72 speedo was a stamped relief to the numbers too, so not really good either.....but unless stared at, it passes ok, the sides of the center plate are odd shaped plates screwed into the dash pads on either side, the top vent/wiper is stock piece, and it all fits in nice.....
mrvette is offline   Reply With Quote
Old 11-02-2012, 03:10 PM   #7
gkz
CF Senior Member
gkz's Avatar
Quote:
With the overlays, you can request a different redline for your tach. (You can see what mrvette is talking about near the rivets.)
gkz is offline   Reply With Quote
Old 11-02-2012, 09:30 PM   #8
The Punisher
CF Senior Member
I like the white overlays. Is there a " how to " on installing them?
Old 11-02-2012, 09:50 PM   #9
Raphiki
CF Senior Member
St. Jude Donor '09-'10-'11-12-'13-'14
Support Corvetteforum!
Raphiki's Avatar
Send a message via Skype™ to Raphiki
Not when I installed mine. They give you the basics but the only tricky part is getting everything properly aligned so 60 is really 60 and not 62. You do have to lightly sand the old gauge faces and clean them thoroughly. Just have to be careful.
Raphiki is offline   Reply With Quote
Old 11-03-2012, 07:51 PM   #10
stopherjones
CF Senior Member
I'm not the best at writing a "how to" but I'll say this...I needed to do something with my gauges. They had surface rust and looked horrible. I very heavily contemplated the "Shark" gauges posted above....But I decided on the white overlays since they were cheap and my oem gauges did function......
The kit I purchased actually had several different year 'vette overlays in the package...I can't remember what all years it covered but there were several...
I lightly scuffed my gauge faces with scotchbright pads and cleaned with alcohol cleaner...I used a small squirt bottle with a drop of soap to keep the vinyl sticker from "sticking" until I felt it was positioned correctly.
I also decided since gauges were apart to go ahead and clean/paint housings..
As you can see they were kinda crusty....Installing the overlays was quite easy...You do not have to remove any needles...Just clean, spray light soapy solution and install. The little screws that hold the gauge faces on actually are used to align the overlays....
The little gauges were just as crappy....
After install
All of it on my "work" bench...
For $20 I was very impressed with the quality of the overlays, them including all the different year models in kit...saved me some bucks and looks great in my new black interior I think....
Old 11-04-2012, 09:18 PM   #11
The Punisher
CF Senior Member
Nice. Do you have to remove the needles for installation ?
Old 11-04-2012, 11:34 PM   #12
Raphiki
CF Senior Member
Raphiki's Avatar
I removed mine. I suppose you could leave them in place but it would be a lot harder. Just be sure to put them back where you found them!
Old 11-05-2012, 08:15 AM   #13
70BBvert
CF Senior Member
70BBvert's Avatar
Auto meter C2 white face gauges. They're blue at night
Jim
70BBvert is offline   Reply With Quote
Old 11-05-2012, 06:18 PM   #14
stopherjones
CF Senior Member
Do not have to remove the needles. The overlay is pretty tough and I believe the instructions say you don't have too either....
Old 11-05-2012, 08:34 PM   #15
rickslt4
CF Senior Member
rickslt4's Avatar
where do you get the overlays??
rickslt4 is offline   Reply With Quote
Old 11-05-2012, 08:44 PM   #16
stopherjones
CF Senior Member
Www.whitefacegauges.net
Old 11-06-2012, 11:43 AM   #17
dmeesq
CF Senior Member
dmeesq's Avatar
http://www.facebook.com/philadelphiaeaglesfan
Send a message via AIM to dmeesq
dmeesq is offline   Reply With Quote
Old 11-06-2012, 03:59 PM   #18
Raphiki
CF Senior Member
Raphiki's Avatar
Quote:
You wouldn't have to if the needles didn't have the extension on the back end. Because the needles extend both ways from the pivot point, you are not able to put the overlays on with the needles in place.
Old 11-06-2012, 07:19 PM   #19
stopherjones
CF Senior Member
Once again....I did not remove my needles, nor did I "tear" the vinyl. It will go over quite easy without removing them.
Old 11-06-2012, 07:31 PM   #20
Raphiki
CF Senior Member
Raphiki's Avatar
I guess we had different experiences! Have you ever considered a career as a magician? I tried everything I could think of but still ended up pulling the needles.
Reload this Page White face gauges
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
