What is this wire/light ? (Pic)
Comes on when I put power to the battery and ignition
Drivers side dash
On a better note....the top dash pad is in and looking good !
Drivers side dash
It will stay on if the door is open. If you still have the timer hooked up it should go off after 10 seconds (or so) once you shut the doors. If it doesn't go off after the doors are shut, either your door jam switch(es) are bad or your timer is shot and should be bypassed or replaced. The timer is located above the tach/speedo and is a pain in the butt to get at.
Adam
Adam
Adam
Adam
The courtesy light will come on when a door is opened, and should go out immediately, upon closing both doors.
With top dash in, start with the bottom of the LH dash, then fold it up to the top dash and attach. (makes it sound easy - huh ? )
Received 3,138 Likes
OP, did you find out what the light was?
What color are the wires to that light?
If the ignition has to be on it shouldn't be a courtesy light (should work with or without ignition)
The only idiot light I can think of over there might be the BRAKE light in the gauge
Mooser
Mooser
Mooser
Mooser
