automatic shifter replacement
http://performanceparts.com/part/B-M/80683 this is the kit I purchased but have not started the install yet. Maybe in the next week or so. Will post pictures as I go along.
my recollection is that the Quick Silver "console version" 80688 has a shorter stick. B&M sells the shorter stick separately as PN 80586, list $40.13 FWIW.
Finally got around to removing the stock shifter today and am going to have to do a few modifications to get the B&M to fit close to stock location. Looks like going to have to cut on the tunnel then weld in an adapter bracket to lower the shifter enough to fit in the stock opening. Going to be a long winter.
Lightning Rods
