LT-1 solid cam - couple of questions
Old 09-08-2012, 09:01 PM
71coupe
71coupe's Avatar
Default LT-1 solid cam - couple of questions
Is anyone using an LT-1 cam with an automatic trans? If so, what stall speed and how do you like it?
Is there any hyd cams on the market that replicate the exhaust note of a real LT-1 cam?
Old 09-09-2012, 07:00 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
For a replica cam try Crane and Competition Cams and they would list comments about stall speed. You do realize it is an ancient design and you could find better cams?
Old 09-09-2012, 07:40 PM
71coupe
71coupe's Avatar
Yeah I know it's a dated design, but I like the sound of an original LT-1 through N11 mufflers
Edit: I found some details for an auto behind an LT-1, since the LT-1 in the Vette was a manual trans only option, the '70 Z28 has an automatic option. It looks like the converter stall was 2400.
http://www.nastyz28.com/camaro/camaro70.php
To LT-1 solid cam - couple of questions
Quick Reply: LT-1 solid cam - couple of questions
