1974 Refresh
Old 08-29-2012, 12:57 PM
jeff06600
jeff06600's Avatar
Default 1974 Refresh
I bought the car 17 years ago. First car. Daily drove it for about six years and occasionally drove it for the following 10. A little more then a year ago I dusted it off, cleaned it up and took it for a drive. I decided it needed to be painted, finally, so naturally I would build a motor first. Pulled the motor and trans that night and broke the motor down.
I took the block and crank to the most reputable engine builder I could find for machine work and after talking engine theory and horsepower across several visits decided to let him build it instead of just doing the machine work.
Then life got in the way of corvette plans until about a month ago when I got back into it. As with everything it has been escalating. Motor and trans turned into cleaning up the engine bay. Which led to rebuilding the front end into power steering where I noticed body mounts when I saw rear suspension pulling the body might as well breaks ss lines... It doesn't end. Front end is done working on pulling the body.
Old 08-29-2012, 01:07 PM
MrJlr
MrJlr's Avatar
'74's are
Old 08-29-2012, 06:50 PM
CQRT
Support Corvetteforum!
CQRT's Avatar
Wow-- great project . . .thanks for the pictures.
Good luck !
Old 09-03-2012, 06:18 PM
jeff06600
jeff06600's Avatar
Point of no return.
Old 10-08-2012, 02:35 PM
jeff06600
jeff06600's Avatar
Finished stripping and cleaning the frame. Working on por15 the frame at the moment.
New body mounts being installed.
Mounts installed, cleaning and prep for por15.
I was hoping I wouldn't have to do the trailing arms this go round. The only thing I thought I might get away with not touching. I did the driver side when I was 19 after the rear leaf pulled out of the rusted trailing arm. No internet guides or pictures back then. A lot of trial, error, and me banging my head inside the wheel well... No such luck on leaving them alone. While pulling the parking break internals from the passenger side, which has been pulled apart in the past, whoever rebuilt it in the past didn't do a very good job and it will need to be redone. Front wheel bearings were very cheap and of Chinese origin. I expect the same in the rear. The passenger side is not rolling very smooth, bearings are shot. Add it to the list.
Old 10-09-2012, 05:39 AM
gcusmano74
gcusmano74's Avatar
Yeah. I've been there.
Once you throw your hat over the fence.............
Old 10-09-2012, 11:15 AM
7T1vette
7T1vette's Avatar
Received 2,715 Likes on 2,273 Posts
Do the T/A's while you have the body off. No doubt they need it and will be 'good-to-go' for the next 30 years when you're done. If you don't want the added work, just have yours rebuilt.
Old 10-09-2012, 02:33 PM
jeff06600
jeff06600's Avatar
Probably not going to reuse the rear leaf...
It has definitely seen better days.
Old 10-09-2012, 05:27 PM
7T1vette
7T1vette's Avatar
Time for a 330# monoleaf rear spring and gas shocks all-around.
Old 10-10-2012, 04:26 PM
jeff06600
jeff06600's Avatar
@7T1vette Front end is done and I already have everything for the rear. Stock all the way around plus an HD Diff cover since the ears on the other one broke off.
Old 10-10-2012, 06:15 PM
7T1vette
7T1vette's Avatar
You're doin' great. Enjoy!
Old 10-10-2012, 11:29 PM
robieWI
robieWI's Avatar
Location: Horizontally parked in a parallel universe. WI
Lookin Good
I'm thinking about going off the deep end too...........
Old 10-15-2012, 04:17 PM
jeff06600
jeff06600's Avatar
Cleaned the underside of frame and por15'd.
Old 10-15-2012, 06:09 PM
PatsLs1vette
PatsLs1vette's Avatar
Looking great ,i see your in eht,im over in absecon and my parents live in eht.I often see the black bmw in your pics around when im out that way.
Old 10-15-2012, 06:49 PM
Rgthoma
Navigator
Rgthoma's Avatar
Nice pics. Good luck, I admire your ambition!
Old 10-17-2012, 01:53 PM
jeff06600
jeff06600's Avatar
@PatsLs1vette I have a hard time hiding with that Beemer. Another fun car though.
Old 10-17-2012, 07:07 PM
PatsLs1vette
im sure you do,its sweet
To 1974 Refresh
Old 03-01-2013, 03:41 PM
jeff06600
jeff06600's Avatar
Finally back to work on it.
Spent last night reconsidering my decision to put a parking brake back on the car. They are not fun to install.
Also picked my transmission up from being rebuilt.
Working more on the parking brake tonight then I have to split the diff. Changing it to a 3.73 before I can put the back end back together.
Old 03-01-2013, 04:07 PM
gcusmano74
gcusmano74's Avatar
IMHO, you need a parking brake on a manual transmission car. How else can you get to the bottom of the driveway, stop, jump out and collect the morning paper without setting the parking brake?
Not necessary on an automatic, of course.
Old 03-01-2013, 04:57 PM
toolman0114
toolman0114's Avatar
Looks great, reminds me of all I went through rebuilding my 74.
Quick Reply: 1974 Refresh
