Replace power brake booster question.
Old 08-26-2012, 09:44 AM
69 N.O.X. RATT
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Replace power brake booster question.
I am going to tear into the 69 a little, new interior, brake booster, steering box, etc.
In Re; the brake booster, would this be an easier job if the enterior is out of the car? I have heard there is a part of this job that is a real PIA that has to do with a bolt or nut that is hard to get to.
John
Old 08-26-2012, 10:01 AM
V4motorsports
V4motorsports's Avatar
Here's a post that might help you: http://forums.corvetteforum.com/c3-t...tips-pics.html
Hope this helps
Russ
Old 08-26-2012, 10:28 AM
69FASTFUN
69FASTFUN's Avatar
I have done it both ways and it is a lot easier with the interior out. I think anybody that is redoing their interior should change out the booster to save them some agrivation.
Old 08-26-2012, 01:01 PM
mrvette
mrvette's Avatar
IF it's a early shark, you pull that dash panel ONCE, and then you modify hell out of the stupid light bulb harness, and put a plug on it from radio shack, that way you have just ONE plug to deal with and a ground wire and a speedo cable, and tack hookup.....simple easy and leave your damn 5000 light bulbs in the housing where they belong instead of pissing you off trying to assemble them again.....
Old 08-26-2012, 01:27 PM
Roco71
Roco71's Avatar
I replaced my P/B booster with the dash out. It took less than a hour the worst part was the clevis on the pedal simple but tricky.
Old 08-26-2012, 04:47 PM
Street Rat
Support Corvetteforum!
Street Rat's Avatar
At the very least have the driver's seat out. I loosened the column also to get a better shot at the fasteners.
Old 08-26-2012, 07:44 PM
69 N.O.X. RATT
That is why I am going to do mine. Car is 43 years old, master cylinder is original. Car is getting paint, interior, steering box, etc...might as well take the brake booster off the list of things that might go worng soon.
Old 08-27-2012, 01:29 PM
jcloving
jcloving's Avatar
The top left nut is the worst one. Use a wobbler and a 10-12" extension. I used a worklight in the floorboard too.
At the time I put my dash back together I had the drivers seat out too. I was able to lay on my back to do some of that work.
Good Luck
To Replace power brake booster question.
Quick Reply: Replace power brake booster question.
