Interesting Tid-Bit's
Old 08-05-2012, 08:04 AM
twinpack
twinpack's Avatar
Default Interesting Tid-Bit's
Stumbled across these while surfing the net and thought they were pretty interesting. Thought I'd share them. I knew many, but there were a few that I wasn't aware of.
* For 1968, a factory installed anti-theft alarm system was available as an option, but less than 400 cars were so equipped.
* Pontiac almost beat Chevrolet to the Coke bottle design body, with their 1965 Banshee, a two seater convertible sports car that would have been hefty competition for the Corvette. GM stopped it, and then Pontiac president John DeLorean later became president of Chevrolet.
* T-top does not refer to the shape of the roof, but rather it is short for Targa Top. The original design was a pure Targa but body flex demanded the center bar, discovered late in the design.
* Due to policy changes at Chevrolet, Corvette was treated like all other car lines for the first time, and quality dropped drastically. With bad publicity in most magazines, policy was re-thought and Chevrolet quickly restored independence and higher quality to Corvette production within a few months. Many believe that all 1968 models still carry the stigma of having "the worst quality" of all Corvettes.
* In 1968, all big block manifolds were redesigned to actually sink into the lifter valley as the hood clearance was less than in '67 and earlier models. As such, a 1965 to 1967 big block intake manifold won't fit in a 1968 or newer Corvette with a stock hood and air cleaner.
* The exception to the above was the L-88. It retained the high rise manifold and also received a special hood, which was externally different to the regular big block hood.
* Emission control equipment was installed on the first 1968 models in the fall of 1967 even though the federal law required it only as of January 1, 1968.
* 1968 was the first year an AM/FM stereo radio was offered as an option
* The "Sting Ray name" was not used on the 1968 Corvette, but returned in 1969, this time spelled "Stingray" as one word.
* Corvette had its first all aluminum engine in 1969 as the ZL-1. It was not the first GM automobile to do so, however, being beaten by the Corvair in 1960 and the Buick 215 V8.
* Only two 1969 Corvettes were sold with the ZL-1 all aluminum 427 engine, making them one of the rarest collector Corvettes of all time. Note: Visit Roger's Corvette Center in Orlando, Florida, for a close-up look at an original 1969 ZL-1.
* In 1969, the ignition lock was moved from the dash to the steering column. It would remain there until 1997 when it was returned to the dash.
* In 1970, big block engines increased from 427 to 454 cubic inches and the powerful 370 HP LT1 small block engine made its debut.
* 1970 sales were their lowest since 1962 (only 17,316 units) due to a late start in the production year.
* The first ZR1 performance package appeared in 1970 (not 1990, as some might believe) and included the 370 HP LT1 engine and a host of other performance items.
* 1971 was the last year for fiber optic warning lights, first introduced in 1968.
* The only external difference between the 1971 and 1972 Corvettes is the amber front turn signals and chrome plating on the egg-crate grills on the 1972.
* 1972 was the only year for Corvette "Big Block" engines in the 1968 to 1972 range to have no horse power sticker on the air cleaner lid.
* Beginning in 1972 and continuing thereafter, horsepower would be measured as "net" rather than the less realistic "gross" ratings of earlier years.
* "Pewter Silver" was only offered as an exterior color in 1972.
* 1972 was the only year air conditioning was available with the LT1 engine and since only 240 were so equipped, this combination is a rare find today.
* Although 1973 VIN's run to 34464, only 30,464 units were built; the 4,000 serial numbers between 24001 and 28000 were never used.
* The 1970 - 1972 Corvettes were the last to feature chrome bumpers front and rear. In 1973, due to front impact legislation requirements, the front bumper was changed to a body-colored flexible plastic. In 1974 the rear bumper followed suit.
* In 1973, aluminum wheels were again listed as an option. However, their inability to maintain air pressure (much like the problems which plagued the early 1963 aluminum knock off wheels), kept them out of the hands of customers until 1976.
* The rear view mirror in the 1974 Corvette was increased to a width of 10 inches.
* The last true dual exhaust was installed in 1974. After that, all exhaust gases were channeled through a single catalytic converter.
* The 1974 rear "rubber" bumper was made in 2 pieces due to shortcomings in the manufacturing process. The process was improved the following year, thus 1975-1982 models used a one piece unit.
* The big block engine made it's final curtain call in the 1974 Corvette.
* The FE7 Gymkhana Suspension package was first introduced in the 1974 Corvette.
* 1974 was the last year the Corvette would be produced to run on "leaded" gasoline.
* 1975 was the first year for a HEI distributor.
* The convertible was discontinued after the 1975 model year and would not reappear again until 1986. GM cited declining sales for convertibles (only 4,629 units in '75) and safety concerns as reasons for killing the ragtops.
* 1976 Corvette used the same steering wheel as a Chevrolet Vega for the "Sport Steering Wheel" Option.
* Due to stricter emissions standards, California Corvette buyers could not opt for the L82 engine in 1976.
* The 500,000th Corvette, a white 1977 coupe, rolled off the St. Louis assembly line at 2:01 P.M. on March 15th, 1977.
* 1977 was the last year for the notch back roof line.
* The aftermarket "Moon Roofs" (glass t-tops for Corvettes) were supposed to be optional equipment in 1977, but the manufacturer had a marketing dispute with Chevrolet. GM developed their own glass panels for the 1978 model year.
* The 1978 model saw the first fastback rear window since 1967.
* The '78 Pace Car's distinguishing "Black and Silver" paint was chosen over other alternative color schemes primarily because it photographed well. Back then, most magazine articles and ads were still done in Black & White!
* Crossed flag emblems returned to the nose and sides of the Corvette in 1979.
* More Corvettes were built in 1979 than in any other year, before or since... a total of 53,807 units were produced.
* Due to tougher emission standards, Corvettes bound for California were fitted with 305 cubic inch engines.
* The 305 cubic inch V-8 installed in 1980 California-bound Corvettes was the first Corvette engine to be monitored by a computer. Since 1981, all Corvettes have been computer equipped.
* By Federal mandate, the 1980 Corvette was the first Corvette to have a speedometer with an upper limit of only 85 MPH.
* There were no optional Corvette engines in 1981.
* The 1981 Corvette had two cooling fans to increase engine power.
* In 1981, Corvettes were produced with two different types of paint. Lacquer was applied at the St. Louis plant, and enamel was applied at the new Bowling Green plant.
* In 1982, console mounted clocks were quartz units and had the word "QUARTZ" printed on the face, while the 80-81 years did not.
* In 1982 fuel injection reappeared in the Corvette after a 17-year hiatus.
* For the first time since 1954, in 1982 you could not order a Corvette with a manual transmission.
Old 08-05-2012, 08:38 AM
bkvette3
bkvette3's Avatar
Thanks for posting. cool facts. BK3
Old 08-05-2012, 08:54 AM
Paul L
Paul L's Avatar
What RPO (option) was available in 1979 and no other year of the C3?
Old 08-05-2012, 09:05 AM
69 Chevy
69 Chevy's Avatar
Roger's ZL-1 #729,219 is hardly original. Close but no cigar.
Old 08-05-2012, 09:16 AM
twinpack
twinpack's Avatar
Sorry, I just found this info and wanted to share it. I copied from another source.
Old 08-05-2012, 09:23 AM
Paul L
Paul L's Avatar
The info was certainly interesting. I was not being critical. Just wanted to add a tid-bit to the list.
Trivia threads used to be quite common here.
Old 08-05-2012, 09:30 AM
desue
desue's Avatar
Glad it turned out that way, that's part of the appeal of these cars!
Couldn't imagine a car without a radio!
And I have one of em!
WTF?! That's an insult. "But officer, I was JUST going 85..."
Good info, thanks for posting!
Old 08-05-2012, 09:34 AM
desue
desue's Avatar
And the answer is???
Old 08-05-2012, 09:41 AM
Paul L
Paul L's Avatar
RPO D80 spoilers, front and rear (6,853 ordered). In 1978 you had to buy the whole (Pace) car to get the spoilers. And of course in 1980 the spoilers were integrated into the new body style.
Jedi926
Jedi926's Avatar
Pretty cool stuff man, thanks for the post
Old 08-05-2012, 09:48 AM
Paul L
Paul L's Avatar
What electrical device was mandated by the US Congress for the 1974 model year and then was cancelled early in the 1975 model year by the same institution following an uproar by the driving public.
Hint:
Old 08-05-2012, 11:09 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Paul,
I don't know.
Is that a 're-set' button on it?
Regards,
Alan
Old 08-05-2012, 11:18 AM
Alan 71
Alan 71's Avatar
Hi twpk,
That's a nice list to look over!
I believe the 71-72 side grills were the same, but, WERE different than the 70 grills. So I guess that item gets 1/2 credit!
Thanks for taking the time to post them all.
Regards,
Alan
Old 08-05-2012, 11:30 AM
Learning_Curve
Learning_Curve's Avatar
Hint:
What is seat belt starter interlock?
Old 08-05-2012, 11:31 AM
moosie982
moosie982's Avatar
Hint:
Seat belt "interlock" ????
Peace,,, moosie
Old 08-05-2012, 11:38 AM
Paul L
Paul L's Avatar
Originally Posted by Alan 71
Hi Paul,
I don't know.
Regards,
Alan
That is part of the 1974 seat belt interlock system whereby the car could not be started unless seat belts were fastened. Sensors in the seat springs signalled an ignition lock-out mechanism when weight on the seat was sensed. Unfortunately, as things turned out, that could be a couple of grocery bags on the passenger seat....So you had to buckle up the bags. Needless to say the interlock feature was not terribly popular and government and car dealers were deluged with complaints (it was industry-wide, not just Corvette).
The pic shows the reset switch under the hood. Once the lock was set you had to hit that switch and begin the starting procedure all over again (with belts fastened).
My system is disabled.
http://www.thedetroitbureau.com/2009...erlock-fiasco/
Old 08-05-2012, 11:39 AM
blk79nj
blk79nj's Avatar
Hi Paul,
I don't know.
Regards,
Alan
I'm going to take a guess... but i think it was devise that wouldn't allow the car to start without the seat belts hooked? I think i remember a having a Cadillac that was like that, but i think it was a '73?.
Old 08-05-2012, 12:28 PM
bpassmore
bpassmore's Avatar
I believe that switch was the over ride for the seat belt interlock system. It was used when the system failed, it was located under the hood so it would be inconvenient to use. It allowed the car to be started one time overriding the "safety" interlock then to make another future start you had to repeat the process.
Later the system was allowed to be disconnected / by passed by the DOT because of the out cry from the owners and other safety issues it generated.
Old 08-05-2012, 08:02 PM
3JsVette
3JsVette's Avatar
Received 2,490 Likes on 1,644 Posts
It's fun to read through that list.
Thanks for taking the time to post it.
To Interesting Tid-Bit's
Quick Reply: Interesting Tid-Bit's
