im looking for some new tires. what ones and whats the max size?
so, im looking at new tires, and im seeing theres no much in options out there.
it looks like a lot of people are using indy 500s, but im not seeing much info on the newish MT S/Ts. they look like theyve got a pretty aggressive tread design on them.
and whats my max size on a standard 15x8 on a 69? im seeing some say i can do 235/60/15s up fronts, and others are saying itll rub. as for the rears, im seeing people say 235 max, maybe 255 max, or even 275s if i get rid of the ebrake bracket.
2018 C3 of Year Finalist
On my '72 I used to run the T/A's in P245/60/15 up front. On my car, a P255 would have rubbed on the front frame. Can't help on the rears as I ran 245's all around for rotation.
I run 245/60-15 on mine. I tried 255/60 but the fronts rubbed. The only problem is availability of 245's. Goodrich T/A's and Cooper are about the only ones.
looks like im going to have to break out the tape measure on this one.
as for the 245/60/15s, M/T has those available. so at this point, unless i find a damn good reason not to, ill be going with the M/T S/Ts.
You can definitely fit 235 width tires in the front on your car; 245's might fit and 255's will likely not fit without some rubbing.
I never checked to see it the 255 60's would rub the frame on the front. I know on my car they clear the fenders ok. I have new coils in the front and will probably lower my front end 1 to 1.5 inch's to close the gap from the fender lip to the top of the tires if I keep the 235's on the front.
Where exactly do the 255/60's rub? It was a factory option on later C3s correct? I thought the clearance problem was with the fender lip, but y'all are saying the frame. Did later C3's have changes in the frame to support the wider tires?
Here's a link to a nice tire size calculator - http://www.miata.net/garage/tirecalc.html
I have a 72. The modern equivalant to the stock tire size is 215/70-15. I don't really like the open wheelwell look - so I like taller/narrower tires. I tried 225/70-15's on all corners, and had rubbing on just the drivers side, full left turn - so they were pretty close. I decided to leave the rears, and I put 215/70-15's on the front.
I was running 265/50Rx15s Dunlop GT Qualifiers had no problems with rubbing I only changed them because they were 12 years old.
I"m now running 255/60x15 Mickey Thompson S/T Sportsman and still no rubbing. Hope this helps.
I just had new BFG 255-60-15 installed at Discount tires for $505 including tax. They matched tirecrawler.com delivered price and installed them for free. Cheapest by far I could find them anywhere.
