What did you use to bond your bumpers?
Just curious to see what people here used when they bonded there bumpers for that "seamless" look. Im a fan of fuzor products but just tryin to find out what others used.
I used SEM 39337 to initially bond the bumper to the body, then glassed in the seams... I know folks have used the Fusor 127EZ and 3M 08115 with good results... The Fusor 127EZ isn't sandable like filler or the other products above, so you'd have to be pretty precise with your application...
ShootCraps-- You must work very quickly... I don;t think I could've applied the Evercoat 870 all the way around my bumper and then secured it with the shoot work time on the Vette Panel Adhesive... I can barely get 5 minutes of spread time when using it as a filler... It is a great product though...
Rogman
Rogman
That's what she said.
I secured the bumper cover, then ground out the seam and filled it with the 870. I used a little less hardening cream to give me a few more minutes of working time with the 870. Takes a couple more hours to cure, but time wasn't critical.
Rogman
Rogman
[QUOTE=rogman16;1581237870]I used SEM 39337 to initially bond the bumper to the body, then glassed in the seams... I know folks have used the Fusor 127EZ and 3M 08115 with good results... The Fusor 127EZ isn't sandable like filler or the other products above, so you'd have to be pretty precise with your application...
Rogman16, hows that sem product and 3m product work? i have more projects of panel bonding and wouldnt mind trying something new.
2. West Systems epoxy mixed w/their 403 filler to bond the bumpers to the body.
3. Slightly grind out the seam and glass in w/epoxy resin.
4. Finish like you would body seams. After leveling, epoxy w/407 filler was used to smooth slight imperfections.
