TKO 500/600 rear tail shaft replacement part number
These things are becoming popular and I guess rear tail shaft seals can get damaged easily and some have said they came with a bad seal? If you need a replacement like I did you can't go into a parts store and ask for a rear seal for a TKO 500/600. The NAPA part number is 16926 for a direct replacement. I found it on a mustang forum. It's either from a 98 mustang or a ford C6, both are suppose to work but the number I listed above is an exact match to what came out of mine.
