Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-06-2012, 01:13 AM   #1
dgheinen
CF Member
Default Rear Right Break Light/Turn Signals
So my 78 Vette has had a problem since I got her. Her right rear brake light doesn't work...when the headlights are on. When the headlights are ON, the running lights work fine, but when I hit the brake, the entire bulb goes dark. When the headlights are OFF, the brake lights work, but the right one is dimmer than the left brake light. Also, when I use turn signals, the right one is much slower than the left.
Is this a grounding problem? I'm going out in the morning to make sure all the grounds are solid and corrosion free. I'll report back with what I find.
I should also mention that I'm running a brand new 1157 bulb.
dgheinen is offline   Reply With Quote
Old 05-06-2012, 04:22 AM   #2
I'm Batman
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
What happens when you turn on the hazard flashers?
I think you might have a shorted out socket on the right side that's causing this weirdness, otherwise the running light filament is completely separated from the brake/turn filament.
I'm Batman is offline   Reply With Quote
Old 05-06-2012, 07:45 AM   #3
...Roger...
CF Senior Member
...Roger...'s Avatar
Sounds like a classic ground issue. The brake light is using the parking light for its ground until the headlights are turned on.
...Roger... is offline   Reply With Quote
Reload this Page Rear Right Break Light/Turn Signals
Tags
brake, corvette, forum, light, signal, turn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
