Anyone besides Alan71 make a list of Matching/Correct Numbers? Here's mine...
CF JASOC Member
1971 Chevrolet Corvette Sport Coupe (37)
VIN - 194371S106XXX
Body Build Date - Jan 9, 1971 (F09)
Ontario Orange (987)
Deluxe Black Leather Interior (403)
Power Windows (A31)
Air Conditioning (C60)
Power Brakes (J50)
Tilt/Telescopic Steering Column (N37)
Power Steering (N40)
F70-15” White Lettered Nylon Tires (PU9)
AM-FM Radio (U69)
Four Speed Wide-Ratio Base Transmission (ZW4)
Custom Interior with Leather Trim
350 Cu.-In. Turbo Fire 350 V-8 270hp
4-Speed (2.52:1 low) 3.36 Rear
Engine Casting - 3970010 Date - L120 (Dec 12 1970)
Engine Stamp Pad - C11S106XXX V1229 CJL
(St Louis Assembly Plant, Flint Engine Plant, Dec 29 1970 - 350/270 4-Speed)
Axle Code - LRW 213E2
(Warren Axle Plant, Julian Date 213, Eaton Positraction, 2nd shift)
Muncie M20 HD 4-Speed (3925661) - P1T21A (Dec 21 1970) C11S106XXX
Cylinder Heads - 3973487 Date - L280 (Dec 28 1970)
Intake Manifold - 3973469
Exhaust Manifolds - 3846559 (RH) 3989036 (LH)
Carburetor - Rochester MV4 - 7041213 DM Date 2310 (231st Day 1970)
CEC Solenoid - 1114444
Distributor - 1112050 Coil - 1115270
Water Pump - Not Original
Alternator - Not Original
Starter Motor - Not Original
Windshield Wiper Motor - 7044758 352 0 2 A
Windshield Glass LOF Date - AT (Sep 1970)
Passenger Door Glass LOF Date - VT (Dec 1970)
Driver Door Glass LOF Date - Not Original
Removable Rear Window LOF Date - AT (Sep 1970)
Lap Seat Belts - C-13 48L90 Not Original
Shoulder Seat Belts - C-24 34B70
Brake Master Cylinder - Not Original
Horn (1) - 9000245 03H (Aug 1970)
Radiator Fan - 3991427 H70 (Aug 1970)
Radiator Fan Clutch - 9 15 70 SC
A/C Compressor - 5910741
Not done yet...
VIN - 194371S106XXX
Power Windows (A31)
Power Brakes (J50)
AM-FM Radio (U69)
Not done yet...
Received 2,878 Likes
Hi Mark,
I noticed your windshield date.
(Relatively early).
Is it LOF SAFETY PLATE, or LOF SAFETY FLO-LIGHT?
Regards,
ALAN
(Relatively early).
Regards,
ALAN
Received 1,470 Likes
Cruise-In II Veteran
Lucky you. Your car was built after the strike so lining up numbers is relatively easy.
My fiancee's 71 was set to be assembled in September with all the appropriate August/September dates and codes on the engine.
Due to the strike, the time/build code is December 3.
CF JASOC Member
Hi Mark,
My understanding is that the difference is in the manufacturing process.
In Safety Plate, (PLATE), each piece of glass is made individually.
In Safety Flo-Lite, (FLOAT) the glass is made in long continuous lengths that is then made into individual windshields.
The second method is a more economical method.
Regards,
Alan
Regards,
Alan
Hi 73,
Not only is it interesting... you can trade that info for a free Big Mac at any participating McDonalds. But, only at the drive-up window.
Regards,
Alan
Regards,
Alan
