Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2012, 02:58 PM   #1
Scottd
CF Senior Member
Default Can I use a square bore carb on spread bore intake?
Ive got a 'Brock spread bore intake on my big block and a 'Brock 1407 carb. (I think its the 1407, standard run of the mill Brock 750 cfm 4bbl) This was how it was set up when I got the car. In order to cure some carb heat sink issues, I installed a spacer/squarebore-spreadbore adapter. The ones Pepboys sells, they are about 3/4 inch thick. Im looking to go to a Holley Avenger as soon as I get home from my deployment (Hello from Kuwait, BTW) and I want everything to work to its optimum potential. I know adapters are made, but is there any performance lost or gained from this setup? Should I swap over to a square bore, run the adapter, or just bolt it on? (The Holley to the spread bore intake) I dont want to dig too deep into the motor yet, but I want to make sure Ive got everything in synch before I decide how much of an upgrade I want to sink into this when I get back.
Scottd is offline   Reply With Quote
Old 04-25-2012, 03:01 PM   #2
MelWff
CF Senior Member
MelWff's Avatar
any adaptor that goes from one type to another will be a compromise. Get the correct combo of carb and manifold. Good luck.
MelWff is offline   Reply With Quote
Old 04-25-2012, 03:48 PM   #3
Scottd
CF Senior Member
The only square bore carbs I see (that Id spend the money on) are Summit remanufactured Quadrajets. I dont know ANYTHING about Quadrajets and have heard they can be problematic. Are they easy enough to work on or sould I just stick with a Holley Avenger and change out the intake manifold? (I dont want to get rid of a perfectly good intake if a Quadrajet can be tuned to run like a Holley)..
Old 04-25-2012, 04:56 PM   #4
73Corvette
CF Senior Member
73Corvette's Avatar
Steve Stovall
The slobber jet is a GREAT carb....when it is on it's awesome have you seen those freaking pop can size secondaries.....geez. Are they as reliable as a Holley, sorry no they aren't. I would try the rebuilt or find a Q-jet guy, usually there is someone around with skills to tweek an old Rochester back to life....
By the way Thank YOU for your service be safe in the sand.......
73Corvette is offline   Reply With Quote
Old 04-25-2012, 08:29 PM   #5
7T1vette
CF Senior Member
7T1vette's Avatar
Not really. There is no "good" way to interchange parts between squarebore and spreadbore carbs/manifolds. There are "adapters" which you can buy...but they only allow the carbs to function with the 'wrong' manifold. They won't work properly or well....
7T1vette is offline   Reply With Quote
Old 04-25-2012, 11:38 PM   #6
I'm Batman
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
Quote:
Q-Jets are spread bore.
The only problematic Q-Jets are those that have been hacked up by morons.
I'm Batman is offline   Reply With Quote
Old 04-26-2012, 02:30 AM   #7
Scottd
CF Senior Member
So Im faced with either swapping the intake and the carb, or buying a rebuilt quadrajet. So I have a few questions about the quad. 1) Will it be bolt on and go like a Holley? 2) How easy are idle and mixture adjustments 3) are their any easy ways to fine tune it for the average street car? and 4) when someone says they arent as reliable as a Holley, what do they mean? Are they as responsive? Thats my biggest concern. The Avenger on my camaro is ultra responsive and all I did was replace the acc pump spring.
Old 04-26-2012, 07:47 AM   #8
BBCorv70
CF Senior Member
I wouldn't buy a commercially rebuilt Quadrajet. Been there. It was a piece of junk. If you decide to go with a Quadrajet, look for one which hasn't been touched by a commercial rebuilder. I bought one a while back from a fellow on this forum. Lars gave it a once over for a very reasonable fee. Like day and night, ran MUCH better than the commercial rebuilt POS.
Otherwise, as much as I like my QJet, you could buy a new Holley if you are concerned with issues dealing with used QJets. Either carb may require some tweaking for your specific application.
BBCorv70 is offline   Reply With Quote
Old 04-26-2012, 03:08 PM   #9
Scottd
CF Senior Member
Are there any distinct advantages to a spread-bore setup?
I really dont want to buy another intake manifold if I can avoid it, so I guess Im stuck running a spread bore for now. Summit sells Quadrajet rebuilds for 300, and I see Holley makes a spreadbore model for around 400. What else are my options, staying under the 400 dollar realm?
Does Lars still do carb work? (Forgive me if Im asking a taboo subject here.....)
Old 04-26-2012, 03:23 PM   #10
MelWff
CF Senior Member
MelWff's Avatar
I think you shoud do nothing to the existing set up as long as it is driveable. Once you are in a position to do more work get a standard bore intake and a suitable carburetor. Any spread bore you buy now you will end up trying to sell once you make more changes.
Old 04-26-2012, 03:34 PM   #11
Scottd
CF Senior Member
Quote:
Why is that? Ill have the money to spend, I just dont want to spend it if its unnecessary. I detest Edelbrock 1400 series carbs because of the horrible heat sink/vapor lock problems Ive had with them. I also hate running adapter plates to counter heat problems and carb/intake pattern differences. If Ill ultimately be happier with a square bore carb and intake, Im all ears to hear why Ill be disappointed with a quadrajet. In not being a wiseass, Im just looking o be schooled on q-jets.
Also- is 750 a good size for a mildly worked 454? All the online calculators say 650 is ample, but Im running a 670 on my modified 350 and its a great combo.
Old 04-26-2012, 03:40 PM   #12
Vette5.5
CF Senior Member
Not sure if Lars is still doing carb work, but good contacting him v8fastcars@msn.com, for his Q-Jet papers. You'll quickly see why he doesn't much like commercially rebuilt jobs. I personally like Q-Jets, but usually go with unmolested factory jobs, and set them up the way I like from there. Main advantage of spread bore designs, is running on the small front two barrels around town, for fuel milage and low rpm throttle response.
Vette5.5 is offline   Reply With Quote
Old 04-26-2012, 04:56 PM   #13
Scottd
CF Senior Member
Quote:
Ill shoot him an email. Thanks. I shudder to think what a unmolested Quad will cost. Where would I even start looking for one? Stay away from remans? Even through a well known company like SUmit?
Old 04-26-2012, 05:03 PM   #14
MelWff
CF Senior Member
MelWff's Avatar
Default Puzzled
You stated in your previous post " Stuck with a spreadbore" and dont want to change the intake! By all means go with the Quad if you can find a good one.
Old 04-26-2012, 05:19 PM   #15
Scottd
CF Senior Member
Gotchya. I mean for now, I think it would make more sense to put the proper carb on the intake and work on tuning the overall car before I really dig into performance issues. From what I know, its a mild 454 (aftermarket cam, headers and intake), so is a Quadrajet 750 too big for the engine?
Old 04-26-2012, 05:25 PM   #16
Vette5.5
CF Senior Member
Actually, just sunk in your mention of a Brock carb and intake, really meaning Edelbrock. Edelbrock carbs were Q-Jets through the mid 90's, so means you probably already have an unmolested one. Believe Edelbrock still sells Q-Jet meter rods/jets and such, so maybe contact their tech line, and see if they'll help you set it up better for your current combination. If getting to much heat from the intake, maybe try partially or fully blocking off the exhaust heat passage. You'll need to remove the intake for this one though. Also, good idea running an enclosed air cleaner housing, hosing in fresh air before the radiator, rather than an open element using hot underhood air.
Old 04-26-2012, 05:36 PM   #17
Jeff_Keryk
CF Senior Member
Jeff_Keryk's Avatar
An Edelbrock 1407 is a square bore carb.
Edelbrock spread bore manifolds usually (maybe always) accept square and spread bore carbs. (But not 4-Jet configurations.)
Edelbrock Q-Jets are numbered 1901, 1902, 1904, 1906 and 1910, I believe.
They are great carbs; the one to get is the 1910 RPM model, but all are great starting points.
"Edelbrock 1407 Performer Series; Carb; 750cfm; Sq Flange Man. Choke;w/o EGR;Incl. Pri. Jet-.113;Sec. Jet-.107;Metering Rd-.071x.047;Dual/Small Single Plane Intake; Street/Hi Perf."
Jeff_Keryk is offline   Reply With Quote
Old 04-26-2012, 05:39 PM   #18
scottyp99
CF Senior Member
scottyp99's Avatar
Have you considered a Holley spreadbore carb like this?
http://www.summitracing.com/parts/HL...555C/?rtype=10
Keep the shiny side up!
Scott
scottyp99 is offline   Reply With Quote
Old 04-26-2012, 06:58 PM   #19
BBCorv70
CF Senior Member
FWIW: Here's a link to a thread regarding Quadrajets vs Holleys. Lars provides a lot of comparative info.
http://forums.corvetteforum.com/c3-t...-question.html
BTW: I have a QJet on my 454, mild cam. Works fine.
It shouldn't be that hard to find an unmolested QJet though it will probably need to be rebuilt.
Reload this Page Can I use a square bore carb on spread bore intake?
Tags
1407, 670, bore, carb, carbs, carburetors, dissipator, edelbrock, good, heat, holly, jet, spacer, spread, spreadbore, square
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
