1968 corvette 327 l79
Old 03-25-2012, 06:34 PM
reel vinyl
reel vinyl's Avatar
Default 1968 corvette 327 l79
hi was wondering if someone could show me a photo of the the crank case vent on the 327 l79 motor i dont know what to look for
the valve covers can be changed and the manifold can be changed
but the sure way to know a 327 is that crank case vent
thanks
Rod
Old 03-25-2012, 07:59 PM
dbeall1968
dbeall1968's Avatar
Sorry, mine does not have the stock covers or manifold, and my spare engine and the original are disassembled.
Old 03-25-2012, 08:20 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If I remember correctly, the SB '68 had a breather tube sticking up from the front of the intake manifold area with a breather cap on it. That was the only C3 year to have that design.
Old 03-25-2012, 08:41 PM
dbeall1968
dbeall1968's Avatar
I think you are thinking of the oil fill neck on the 327.
Old 03-26-2012, 06:52 AM
Phil Zell
Phil Zell's Avatar
I believe 7T1 is correct
Old 03-26-2012, 09:48 AM
Mike Ward
Mike Ward's Avatar
Here's what you're looking for. The tube at the front mentioned above serves as the oil filler tube and the inlet for the PCV system I believe.
http://www.fossilcars.com/chevrolet-...-intake/175016
Old 03-26-2012, 11:16 AM
loup68
Support Corvetteforum!
loup68's Avatar
The tube in the front is only for oil fill, on the 327's only. Older C-2's had a tube on the side of the oil fill tube for the pcv hose. The original 68 L-79 only chrome valve covers each had one hole in them. The left hand side was for the pcv valve and hose and the right hand side was for a metal tube and hose up to the air cleaner base spark arrester.
Old 03-26-2012, 12:08 PM
7T1vette
7T1vette's Avatar
My recollection was incorrect. That tube is just for oil fill and had a sealed fill cap on it. Thanks for the correction.
[I'm told that "memory" is the second thing to go, as we grow older; but, I can't remember the first... ]
Old 03-26-2012, 04:27 PM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
For the 68 327s, the PCV valve is in the left valve cover and connects by hose to the base of the carburetor. AIM shows it. 68 327s have no road draft tube like earlier small blocks had.
Old 03-26-2012, 04:44 PM
reel vinyl
reel vinyl's Avatar
hey you guys have all been great 7t1 vette youre hillarious!!! but Tom Falconer collectors guide says page 18 "valve covers and intake manifolds could be changed but there is no question about that rear block vent" so my question to you friendly fellas is where is it??
and what is it ?? he calls it a crank case vent at the back of the block just beside the
distributer
thanks Rod
Old 03-26-2012, 06:17 PM
7T1vette
7T1vette's Avatar
Someone with a copy of the '68 AIM would have to assist on this one, I think.
Old 03-26-2012, 07:49 PM
Easy Mike
Easy Mike's Avatar
...Someone with a copy of the '68 AIM would have to assist on this one, I think...
I re-read that section in Mr. Falconer's book and I am wondering whether he might be mistaken.
The plug looks like a small freeze plug. I have seen them, but only on older small blocks. It is on the pad on the block to the left of the distributor and very close to the oil pressure line fitting if it is there.
If memory serves, my original 327/300 assembled in April, 1968 does not have the plug.
Old 03-26-2012, 08:15 PM
Mike Ward
Mike Ward's Avatar
[IMG]
Here's a bare block with the hole Mike is referencing.
In earlier years (pre-PCV) a road draft tube was installed as crude method of venting crankcase vapours. That's what caused the filthy black strip down the center of many 50s and 60s highways.
Old 03-26-2012, 08:35 PM
reel vinyl
reel vinyl's Avatar
thanks for the info guys as i became a little nervous after reading Mr Falconers guide but with all due respect to him i took it as bible perfect and no one is perfect... so with that in mind i thought maybe i coudlve had a fake 327 even though the block #s match the vin in the window if you guys go to my profile you can see a pic of my motor
kind regards and many thanks
Rod
Old 03-26-2012, 08:37 PM
Paul Borowski
Paul Borowski's Avatar
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...three pics from the very original 42,000mi Silver '68 L-79 4spd car I used to own.
Old 03-26-2012, 08:41 PM
reel vinyl
reel vinyl's Avatar
thanks Paul looks the same as mine minus ignition shielding ...take a peek at my motor on my pics if you get a chance let me know your thoughts....
Old 03-26-2012, 08:46 PM
Mike Ward
Mike Ward's Avatar
Rod
Why not tell us the casting numbers, dates and stamp pad info if that's what you're really asking.
To 1968 corvette 327 l79
Old 03-26-2012, 08:54 PM
reel vinyl
reel vinyl's Avatar
sure id be happy to do that its getting some minor mechanical right now though...would the vin # help for now???? i can submit the casting #s wednesday or thursday...i know also it has an HT on the block as well
Old 03-26-2012, 08:56 PM
Paul Borowski
....your set up looks correct, minus the smog set-up.
Old 03-26-2012, 09:08 PM
reel vinyl
reel vinyl's Avatar
thanks Paul ......whats smog set up?
Quick Reply: 1968 corvette 327 l79
