Best Carpet? Loop or Pile?
I'm almost to that point where I need to order my replacement carpet.
And I'm hearing Al Knoch or Ecklers as highly recommended vendors (open to other suggestions), but what I'm also questioning is 80-20 loop or plush cut-pile.
I know there are a number of you folks who've already done this, and I'm wondering how satisfied you are with the loop or the pile???
Loopor Pile... SOunds like Gomer's cousin.
Just received my replacement carpet from Corvette America. My car only came with the cut pile but I think it looks better than the loop. That's probably why it only came with deluxe interiors.
Received 1,468 Likes
Cruise-In II Veteran
Loop came with standard interiors. Plush cut came with the optional custom interior package.
Choice is up to you.
"Loop" pile for the base model interiors; "cut" pile for the deluxe interior package. Cut-pile carpet is the same as "loop" pile carpet...except the very top of the loops are cut off.
Loop pile wears better; cut pile carpet can be cleaned easier. If you don't care that the 'correct' type of carpet is reinstalled in your car, pick the one you prefer.
i feel really stupid right now i have no clue what you guys are talking about
what is the loop or pile is it the way they ar cut or ??? who has a picture of the one vs the other so i can see the difference?
Almost all carpet is woven in a loop. Plush cut only means that the tops of the loops in loop carpet are cut. You can see the loops in loop carpet. Plush cut looks fuzzy instead of loopy.
Guys ,i thought in 68 and 69 vettes only came with loop pile ,also if you look up carpet for a 69 it only says loop. So did 68 and 69 come with cut pile?
Received 2,878 Likes
Hi,
Here's a close-up of original 80/20 'loop' pile carpet.
I think 80/20 refers to the materials it's made from (?), nylon+?
Regards,
Alan
At first the custom interior's cut pile was only available in black and saddle.
Regards,
Alan
Received 3,134 Likes
Mooser
Oh, here's a pic of the cut-pile
Does anybody know the answer to my question above,for i donot know.I have looked into ordering carpet for my car and i like cut pile better,but the venders advertise that loop pile is the only choice for a 69.I know you can fit other years,i was just wondering why just loop pile
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 80/20 did stand for the percentage of materials and yes they were rayon and nylon.
Willcox
Carpet sets are on sale at the link below in the forum special section side of the site:
Use the coupon code and you'll save an additional 10 percent.
http://willcoxcorvette.com/advanced_...eywords=carpet
1 Post
I am currently installing my loop carpet from Wilcox. The back is in, and I laid in the passenger side to see how it fit- IT FITS PERFECTLY!!!
I ran out of glue, so after work tomorrow I will pick up more, I should have it in in a few more hours. I took the time tonight to remove, sandblast, and re-paint the seat and seatbelt bolts. I used the hot bolt trick to make my bolt holes in the carpet. It worked great.
