Best Carpet? Loop or Pile?
Old 03-14-2012, 11:22 PM
bhk2
Support Corvetteforum!
bhk2's Avatar
Originally Posted by dbeall1968
I am currently installing my loop carpet from Wilcox. The back is in, and I laid in the passenger side to see how it fit- IT FITS PERFECTLY!!!
I ran out of glue, so after work tomorrow I will pick up more, I should have it in in a few more hours. I took the time tonight to remove, sandblast, and re-paint the seat and seatbelt bolts. I used the hot bolt trick to make my bolt holes in the carpet. It worked great.
Can you elaborate on the hot-bolt trick? I have a guess, but needed confirmation.
Old 03-14-2012, 11:48 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Heat the end of a bolt and melt a hole in the carpet with it.
I prefer using a pencil-type soldering iron. But, I locate those holes first with a large needle...then mark the exact location of the hole.
Old 03-15-2012, 02:25 AM
AdamMeh
AdamMeh's Avatar
I used an old screwdriver which I have ground down to a point to locate the hole and then my soldering iron to melt the hole. It makes a nice round hole for the bolt and melts the carpet ends which will keep it from fraying.
Old 03-15-2012, 05:19 AM
dbeall1968
dbeall1968's Avatar
Bingo. I did use a pointed screwdriver to first locate the hole, then a 1/2" bolt heated to make the hole.
Old 03-15-2012, 05:19 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi David,
It sounds like you're making some good progress.
I smiled at your comment..... is a POINTED screwdriver STILL a screwdriver!?!?
Good Luck as you continue!
Regards,
Alan
Old 03-15-2012, 06:32 PM
champs65
champs65's Avatar
Originally Posted by Clubby99
I like loop. It looks more Old School. I have it on my deluxe interior car with matching loop door inserts.
Never really liked the look of cut pile or the feel of cut pile on my hands.
Old 03-15-2012, 11:19 PM
slopoke17
slopoke17's Avatar
I'm going to start installing my carpet, what type of glue did you use?
Old 03-16-2012, 07:29 AM
Stroh
Stroh's Avatar
I'm wondering the same thing????? Best glue choice????
Old 03-16-2012, 07:47 AM
KevinG
KevinG's Avatar
3M spray adhesive (should be found at Lowes or Home Depot)
Old 03-16-2012, 01:53 PM
slopoke17
slopoke17's Avatar
Hey Stroh, I like your ride! Don't see too many silver/smoke interior combos.
Old 03-16-2012, 02:00 PM
73Corvette
73Corvette's Avatar
Kevin could you please find us a BIGGER picture.....
Old 03-17-2012, 06:10 PM
dbeall1968
dbeall1968's Avatar
I used the 3M, but I used the high strength spray- 08090.
Alan- I did mean phillips, but it was late!
Old 03-17-2012, 06:32 PM
  #33
garage-ghost
garage-ghost's Avatar
I like cut pile because when it starts to look shaggy you can take a set of electric hair trimmers, with the proper attachment, and give them a good trimming and they look new again.
Old 03-17-2012, 08:07 PM
  #34
Billysvette
Billysvette's Avatar
Never heard of that , or is this a joke?
Old 03-18-2012, 11:10 AM
  #35
garage-ghost
No joke..It really works. I've done it for years.
Old 03-18-2012, 11:50 AM
  #36
Billysvette
How exactly do you do this with clippers? and keep everything looking uniformed?
Old 03-18-2012, 03:02 PM
  #37
Stroh
Stroh's Avatar
Thanks Slopoke... Yours looks awefully sharp too.
And thanks everyone for the input on the loop or cut pile... My choice is going to be the loop... It's just feels right for my ride. Pics to follow.
Old 03-19-2012, 09:23 AM
  #38
garage-ghost
Clippers come with attachments to keep the height uniform. Just clip on the right one and go to it.
Like these:
http://www.amazon.com/Wahl-Clipper-A.../dp/B000FL6HEC
Quick Reply: Best Carpet? Loop or Pile?
