68 Ride Height adjustment
Old 05-08-2015, 09:35 AM
ksbunting
Support Corvetteforum!
ksbunting's Avatar
Default 68 Ride Height adjustment
Does anyoneknow how to adjust ride height on my 68?
Driver side at the rear is 1 inch lower than the passenger side.
Thank you,
Kurt
Old 05-08-2015, 10:29 AM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
That could be rear spring bolts. Do left and right appear to be set the same?
Old 05-08-2015, 10:42 AM
ksbunting
ksbunting's Avatar
Yes the left and right bolts appear to be even
Old 05-08-2015, 11:42 AM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
OP did you look at your other post?
https://www.corvetteforum.com/forums...djustment.html
Old 05-08-2015, 04:13 PM
ksbunting
ksbunting's Avatar
yes
To 68 Ride Height adjustment
Quick Reply: 68 Ride Height adjustment
