Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2012, 10:01 PM   #1
2001convertable
CF Senior Member
2001convertable's Avatar
Default 1971 removal of dash pad
Hi, can anyone tell me the proper way to remove my dash pad. I would think remove the screws on the top of each dash panel left and right then top of the wiper bezel. I dont want to break anything. thanks
2001convertable is offline   Reply With Quote
Old 03-03-2012, 11:00 PM   #2
Mooser
CF Senior Member
Support Corvetteforum!
Mooser's Avatar
The entire car was built around the dash pad.
Do a search, this just came up a week or so ago, Willcox has a paper available that gives a pretty good description on how to remove/install (later model I think but the general idea)
The biggest tip is to make sure it's nice and warm, it needs to be flexed some. I've even heard of hair-dryers and hot towels
Mooser
Mooser is offline   Reply With Quote
Old 03-03-2012, 11:05 PM   #3
Mooser
CF Senior Member
Mooser's Avatar
found the link
http://willcoxcorvette.com/repairand...lp.php?hID=105
Seems to me they added to drop the column helps a lot
Mooser
Old 03-04-2012, 07:48 AM   #4
Big Block Dave
CF Senior Member
Big Block Dave's Avatar
Quote:
Originally Posted by Mooser View Post
The entire car was built around the dash pad..
Aint that the truth! Pretty much if you take off the sunvisors, top windshield header panel, side windshield panels, and then remove the screws that attach to the driver instrument pad, center instrument cluster, and pass side pad, then you can reach under the pass side, and remove the one retaining screw, and then wiggle the clips loose. Then it becomes a delicate game of bringing one side up, pulling the other one back, and eventually you will get it out....
...Its kind of like getting a couch through a doorway
Big Block Dave is offline   Reply With Quote
Old 03-04-2012, 08:43 AM   #5
Willcox Corvette
Premium Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Willcox Corvette's Avatar
https://www.facebook.com/WillcoxCorvette
Send a message via MSN to Willcox Corvette
Mooser is correct... If you are going to remove the left lower pad it is imperative to remove the steering column. It's not all that hard and it makes the installation and removal of the dash pad so much easier.
Pay special attention to the notes at the bottom of the first page... One thing people fuss about when doing the left pad is getting to the tach and speedo cable behind the dash pad. Removing them from the distributor (68-74) and the tranny will allow you to pull the pad toward the car for easy removal.
We need to just combine the two pages, it's just a time issue for me.
You'll find this page will help you if you are removing the left dash pad
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
If you are just doing the right pad and/or upper pad then go to this page.
Corvette Dash Pad Remove and Install Instructions 68-77
Willcox Corvette is offline   Reply With Quote
Old 03-04-2012, 10:08 AM   #6
2001convertable
CF Senior Member
Hi, I hope I explained myself correctly. I would like to remove the top pad that runs along the windshield. I would like to remove the instrument panel pad later to install the new vent and eliminate some old alarm wiring later. thanks for the help so far. Anthony
Old 03-04-2012, 10:55 AM   #7
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Quote:
Originally Posted by 2001convertable View Post
...I would like to remove the top pad that runs along the windshield...
Purchase the assembly instruction manual (AIM) from Willcox and take a look at the factory installation. Top pad has a hidden bolt in it which you will have to remove. Passenger's side lower dash has to come out to get to the bolt.
Easy Mike is offline   Reply With Quote
Old 03-04-2012, 10:55 AM   #8
Clubby99
CF Senior Member
Clubby99's Avatar
Yes, the prior posters understood and provided your answer. Not an easy job. Many other parts need to be removed first. Plus remove other parts to access hidden screws. You will also likely crack your dash so be prepared.
Clubby99 is offline   Reply With Quote
Old 03-04-2012, 11:57 AM   #9
Alan 71
CF Senior Member
Alan 71's Avatar
Hi 2001,
What's misleading is that all the screws you see are for mounting the lower pads and center gauge bezel to the upper dash pad. They really have little to do with getting the upper pad out.
I agree with Mike, I wouldn't even attempt to start taking the dash apart without having the 1971 ASSEMBLY INSTRUCTION MANUAL, and having looked very carefully at it. MANY EXPENSIVE parts to break in a 41 year old dash and interior!
Good Luck!
Regards,
Alan
Alan 71 is online now   Reply With Quote
Old 03-04-2012, 12:04 PM   #10
Big Block Dave
CF Senior Member
Quote:
Alan..I should have taken that advice, as I did have the instruction manual...however when I did it, it was kind of like pulling at a loose thread on a sweater, that resulted in the dismantling of the whole sweater....
Best part was that I left the interior unassembled for about 8 months before I started to put it back together. It was kind of like the episode of Happy Days when Fonzie went blind, and had to reassemble his motorcycle after Ralph and Potsie took it apart.
At least my car is back together, and the Fonz got his site back by the end of the episode
Old 03-04-2012, 12:05 PM   #11
Big Block Dave
CF Senior Member
Just realized...hey Mr 2001 convertible...I live one town away from you, and I did this job last summer. Would you like a hand with this surgery?
Old 03-04-2012, 12:46 PM   #12
Clubby99
CF Senior Member
Clubby99's Avatar
Quote:
He will blame you when he cracks his dash.
Old 03-04-2012, 06:26 PM   #13
Willcox Corvette
All the info needed can be found in the links I've provided.
Old 03-05-2012, 07:21 AM   #14
Roco71
CF Senior Member
I have removed my upper dash three times on my 71 using Wilcox's instruction without any problems. I would say that warmer weather is probably your friend when doing it.
Best of luck.
Roco71 is offline   Reply With Quote
Old 03-05-2012, 07:24 AM   #15
Willcox Corvette
Quote:
Best of luck.
And a six pack too! LOL
Old 03-05-2012, 08:02 AM   #16
Indiancreek
CF Senior Member
Ha Ha with a six pack the collateral damage could be extensive in my case.
Indiancreek is offline   Reply With Quote
Old 03-05-2012, 08:37 AM   #17
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
Half a case at the least.
Old 03-05-2012, 08:43 AM   #18
73Corvette
CF Senior Member
73Corvette's Avatar
Steve Stovall
Sorta like trying to put a worm on a hook....truthfully, i was more intimidated and had more trouble with the consoles...getting all the holes lined up and getting things where they need to be is tricky. Taking it apart was the "easy" part.
73Corvette is offline   Reply With Quote
Old 03-05-2012, 10:21 AM   #19
Roco71
CF Senior Member
Quote:
Your right Mike... six to get it out and another six to put it back.
Old 03-05-2012, 12:44 PM   #20
2001convertable
CF Senior Member
Hi, I think Iam going to have Dave help me with this. Iam almost done with the interior. Waiting on Willcox for my console parts. They were great the interior. The only things I need to do is the seat covers with foam and install the new console parts I ordered. I wanted the dash pad out to change the speakers....thanks again guys
Reload this Page 1971 removal of dash pad
Tags
1971, 1972, c3, corvette, dash, dashboard, instructions, pad, removal, remove, removel, speedometer, upper
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
