Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-20-2012, 06:57 PM   #1
Mooser
CF Senior Member
Support Corvetteforum!
Mooser's Avatar
Default Parking brake install
It's just like stepping on your own head...
Well today seemed like a good day to put the new spindles onto the T/A's
When I ordered the spindles I already had all of the parking brake pieces (stainless kit from a while ago) and the pads seemed fine (one set new and one set on the car when I bought it for the safety inspection)
Anyways, had to install the parking brake bits with the spindle in place so more or less it's the same PIA as if it was on the car.
Put the one pad in place and while holding it out as far as possible, slip the spring over the pin and using needle nose pliers put the cap on and give it 1/4 turn
Hooked the upper and lower springs onto that pad and looped some strong nylon string to the open ends
Click the image to open in full size.
Put the second pad in place and using one hand to hold the pin up, use the other hand to hold the pad away as far as possible and use the other hand to put the spring and cap on... oh wait, tried taping the pin up but it doesn't work, ended up using one finger through the vent hole in the shield to hold the pin and the same thumb to manipulate the pad. Again with the needle-nose pliers to put the cap on and turn 1/4 turn
Now, using the string on the spring, pulled the bottom spring out to align with the hole in the pad, small flat screwdriver through the hole in the spindle flange to pop it into place
Same routine for the top spring, much harder to pull since the bottom is in place now, wrapped it around my hand and pried against the pad with my thumb to pull the spring. Same screwdriver through the hole to pop it into place.
Pull the string out and check the actuator arm to make sure it's in the right place
Sneak the long side of the star adjuster under the one pad and then pry them apart slightly to get the short end in, then align the slots with the pad and check everything for being straight and working properly
Not nearly as bad as it was the first time
I've left the adjuster all the way in since I still want to dial in the rotor. Then I'll worry about bringing it out closer to where it should be
Anyway, probably cover lots of time before but it worked pretty good for me so figured I'd post it.
Mooser
Mooser is offline   Reply With Quote
Old 02-20-2012, 07:01 PM   #2
corvetteload
CF Senior Member
corvetteload's Avatar
Too bad all that wasted time for something 99.9 % of the people who drive don't use, nor inspection mechanics don't check!!!! Nice effort though.........
corvetteload is offline   Reply With Quote
Old 02-20-2012, 08:52 PM   #3
my 76 ray
CF Senior Member
my 76 ray's Avatar
Nice method. It will help a lot of people.
my 76 ray is offline   Reply With Quote
Old 02-20-2012, 10:15 PM   #4
speedreed8
CF Senior Member
speedreed8's Avatar
Quote:
inspections in texas it must work, and must hold the car with it in drive
while apply throttle, almost impossible to get it to hold. i gave up this year and registered the car as an antique, no inspections, and 5 yr. registration permit. nice write up, i've done it twice and hated it both times.
speedreed8 is offline   Reply With Quote
Old 02-20-2012, 10:35 PM   #5
TurboStitchCW
CF Senior Member
TurboStitchCW's Avatar
turbostitchcw turbostitchcw CleavageWarmer
Send a message via AIM to TurboStitchCW Send a message via Yahoo to TurboStitchCW Send a message via Skype™ to TurboStitchCW
just did mine recently also and found out that one of the PO's didn't line the holes up right, so I had to attach the top spring up first, slide the pads on, then (with dental floss putting tension on the springs to about half their length), slid them onto the pins and twisted the caps on. After they were secured, I attached the lower spring coming up from the bottom. After I had that attached, I pried (pry'd? pryed?) the pads apart and slid the adjuster arm thing in.
After all of that....my parking brake still doesn't work. The last thing i have to replace is the upper parking brake wire....if it doesn't work after that, I'm out of ideas. I have to have it working in order to pass safety here in Hawaii. (Plus, I would like all of the systems to work as they did back in the day)
(great write-up, sorry if I hijacked your thread)
TurboStitchCW is offline   Reply With Quote
Old 02-21-2012, 08:04 PM   #6
GPGG70
CF Senior Member
GPGG70's Avatar
Thanks Mooser!! I for one do appreciate the write up, cause I'll be installing my EB soon and any write up or info other have to share here on the forum helps.
Let us know how your runout checks out.
Thanks.
GPGG70 is offline   Reply With Quote
Old 02-25-2012, 10:12 PM   #7
Mooser
CF Senior Member
Mooser's Avatar
Got the rotors shimmed today and the brake pads more or less adjusted (a little looser than the 6-8 teeth the manual said, brought them out until they don't touch. I'll fine tune them once the T/A are on and the cables and everything are back on. Pretty easy to adjust through the access holes
Got the runout down to just over .001 and .0017 on the front (.0013 and .0015 on the back, not bad since they weren't re-turned)
.004 shim on the one and .006 on the other so I'm plenty happy with that.
Checked the end-play (PITA!) set by VanSteel on the Hubs and got pretty much .0025 on both
Anyway, looks like both arms are done and I can bag them up ready for re-assembly
( another job off the list)
Reload this Page Parking brake install
Tags
1972, 2008, 66, brake, c5, c6, cable, corvette, emergency, emergencybrake, install, installation, parking, short, wire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
